http://www.minisport...ndard-each.html
^^Are these caps on the end of the joint or does the whole lot slot in? From what I can remember when I removed mine it was just the joint(ball) on the end, would I have to remove the bit still attached the subframe ? And are these on the front and back or just the back ? (Haven't taken apart the front subframe yet)
Also most of the rubbers on the front subframe look torn/ perished, could anyone tell me what I would need for all of the rubbers to be new on the front? Any kits or anything ?
Thanks in advance !
Knuckle Joints And Front Subframe Question
crf150
, Jul 22 2014 08:55 PM
1 reply to this topic
Posted 22 July 2014 - 08:55 PM
Posted 22 July 2014 - 09:25 PM
They look like the entire joint including the ball sleeve that sits in the upper arm on the front and the radius arm on the rear.
All replacement subframe bushes and mounts etc can be purchased in standard or poly from any of the main mini stores individually or in sets.
