Posted 22 July 2014 - 09:50 PM
I've been out off and on the past couple days with a multimeter, prodding, poking, trying to work it out...here's my dilemma....my mini is an 83 mini. 998 mayfair. I'm told it was sporadic wether they put on a ballast or not around then, and standardised it more around 84?
It's got a DLB101 coil, which looking around tells me is a 12v - 3ohm coil. Great...non ballasted.....
....however I have 2 wires on said coil, one pink and white and one yellowish and white thus pointing to ballasted?! Also...multimeter on coil with ignition on gives me solid reading of just under 8 volts.
Is this a potential loom burning fire bomb, someone's put on the wrong coil, or have I got the wrong end of the stick here?
Any advice greatly appreciated. I mention the word ballast to a mechanic nowadays and they look at me like I'm from the moon. "If it ain't got a computer to plug into it then god knows"
Thanks again in advance.
Neal
Posted 22 July 2014 - 09:59 PM
Put a 12v coil on it & run a new 12v switched supply from the fuse box to the coil .
Edited by geoff-d, 22 July 2014 - 10:00 PM.
Posted 22 July 2014 - 10:00 PM
Run a new white wire to coil positive from the fusebox(white wires)
A good coil to buy is a GCL143 Unipart item, ive had one on our 998 and i bought it 2nd hand
Edited by cal844, 22 July 2014 - 10:08 PM.
Posted 22 July 2014 - 10:45 PM
Posted 23 July 2014 - 12:11 AM
Please read Neal's post. He says he has coil DLB101. That is a standard 12V, non-ballast coil. He does not need to buy a different coil. Since you have a standard, non-ballast coil you want to provide it the proper operating voltage by running a new 12V supply wire to the coil. As wired now, you have a 12V coil that will be operating at low voltage and therefore will be making a weak spark.
I believe KernowCooper (a.k.a. Dave) has placed an article in the FAQ section which discusses wiring changes when going from a ballast to non-ballast ignition. Succinctly, remove the pinkish wire from the coil and tape it off. You can remove the white/yellow from the coil and tape it off OR leave it on the coil if you want... it won't hurt anything to leave the white/yellow on the coi. Run a new white wire from the fuse box to coil (+). That will supply your 12V coil with full battery voltage so it will operate properly.
Technobabble to follow:
When you are measuring the voltage between coil (+) and earth you need to insure that current is flowing. To do that, remove the distributor cap and place a coin between the points. Turn the key to the run position and measure the voltage between coil (+) and earth. If you measure 12V on coil (+) you have wiring for a standard coil. If you measure between 6V and 9V, you have wiring for a ballast coil. To measure the coil itself, mark and remove the low-tension wires from the coil. Set your meter to measure Ohms and place its two leads on the two low tension coil terminals. A standard coil will measure around 3 Ohms. Ballast coils will measure anywhere from 1 Ohm to 2 Ohms.
Posted 23 July 2014 - 01:09 AM
Thanks Doug that really helps. So that would explain why i feel she isn't running quite as she should?
As for the dizzy in this car, am i right in thinking its a 59D on the later A+ engines? It has no literature on it but taking a punt that it is? just so i can buy the correct ignition kit!
Thanks again all of you. I can only assume she's been running pretty under powered all this time due to the coil being fed the wrong voltage!
![]() 1986 Mini Chelsea - Main Beam IssueStarted by Dominic1998 , 25 Apr 2025 ![]() |
Mini Technical Sections →
Problems, Questions and Technical →
Understanding The Starting System / AlternatorStarted by Jaybraham , 18 Feb 2025 ![]() |
Identifying Wiring Diagram/loomStarted by Jaybraham , 02 Feb 2025 ![]() |
![]() Are Auxiliary Switches (Fog,hazard Etc) Supposed To Be Backlit At Night?Started by leehine54 , 31 Jan 2025 ![]() |
Which Ignition Coil?Started by daddums , 27 Jan 2025 ![]() |
