can i drill my A+ head to take A series heater tap?
9 replies to this topic
#1 daniel_johno
daniel_johno
  • 310 posts
  • Local Club: AMOC
Posted 25 June 2006 - 12:21 AM
I have an A+ turbo head and want to fit the mini heater tap to it but the hole is sealed for the metro type heater tap.
Can i simply drill through the head casing to open up the water channel or is specialist machines needed and is it best for me to take it to an engien shop.
Thanks for looking
Dan.
#2 miniboo
miniboo
    Lord of Original Thinking
  • 9,327 posts
Posted 25 June 2006 - 06:02 AM
Simple answer: YES and you can drill it out yourself the screw holes should already be tapped.
#3 daniel_johno
daniel_johno
  • 310 posts
  • Local Club: AMOC
Posted 25 June 2006 - 03:09 PM
yeah the screw holes are tapped, so i just drill the hole out starting with a small drill bit and working up? is there any chance of drilling through an oil channel or doing damage to the head?
Thanks for the reply
Dan
#4 crb
crb
  • 30 posts
Posted 25 June 2006 - 04:28 PM
just done mine 15 mins ago no prolems
#5 Lomcevac
Lomcevac
  • 275 posts
Posted 25 June 2006 - 08:13 PM
You're pretty safe as you are deliberately drilling into a waterway anyway.
#6 minifunclub
minifunclub
  • 90 posts
  • Local Club: minifunclub
Posted 30 July 2008 - 10:41 PM
Hi Guys...........
Looking at doing this myself, are there any pitfalls to watch out for such as swarf findinding it's way into the water pump etc?
Got a brand new med 1380 (just about to fire it up) and don't really want any *rubbish* floating around inside it.
#7 998dave
998dave
    998cc's Of Dave Goodness
  • 4,566 posts
  • Name: Dave
Posted 31 July 2008 - 10:54 AM
you should really do it with the head off the engine, and give it a good clean out afterwards.
Small drill to get a lead hole then up in a couple of steps is probably the best way.
D
#8 Ethel
  • 26,073 posts
Posted 31 July 2008 - 11:32 AM
DJ's suggestion has given me an idea - drill a small hole and inject some grease through it to catch the swarf ;D There's little point in drilling larger than the bore of the valve's outlet.
#9 m1n1
m1n1
  • 768 posts
  • Local Club: I'm unsociable
Posted 31 July 2008 - 01:58 PM
I used a vacuum cleaner to suck out all the debris. Worked VERY well. And no problems 7 years down the line.
#10 minifunclub
minifunclub
  • 90 posts
Posted 31 July 2008 - 05:12 PM
Thanks for the suggestions guys...............
May fire the engine up this weekend while I consider either drilling tap out or using later valve and sandwich plate from a later car!
