Another Re-Torque Question
2 replies to this topic
#1 Magna-Flash
Magna-Flash
  • 78 posts
Posted 24 July 2014 - 12:40 PM
I know there are a lot of threads about re-torqueing heads - however, here´s my question...
Once you´ve torqued all the nuts, you run it warm, let it cool and re-torque, right?
But - in what order do you loosen the nuts (and how much)?
One nut at a time or loosen all then re-tourqe?
If one-a-time... do you start with the last one you torqued the initial sequence? Or the last one (backwards)?
I have a Monotorque gasket (says it needs no re-torque) that is starting too seep a tiny bit between head and block, so considering to re-torque it...
#2 Gremlin
Gremlin
  • 2,142 posts
Posted 24 July 2014 - 12:52 PM
If it's a monotorque head gasket I'd take the head off and find out why it's seeping
#3 Cooperman
  • 23,326 posts
Posted 24 July 2014 - 10:08 PM
Using the same sequence as for initial torqueing-up, back each nut off 1/2 of one full turn, then re-torque doing one at a time to the specified full torque. Ideally a couple more lb.ft. than at initial torqueing-up.
Then re-set the valve clearances.
