Gear Box Crunching In 2Nd
12 replies to this topic
#1 sonicc
sonicc
    Just On Tickover
  • 9 posts
Posted 26 July 2014 - 04:21 PM
Hi there guys, had my mini a week now and there seems to be a crunching in 2nd gear. Any ideas what it could be?
#2 jonny f
jonny f
  • 1,485 posts
  • Local Club: Boxhill Mini Club
Posted 26 July 2014 - 04:29 PM
Possibly a synchro.
Engine out job :(.
EDIT: see below, I meant baulk ring but had Honda on my brain.
Edited by jonny f, 26 July 2014 - 05:16 PM.
#3 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 26 July 2014 - 04:33 PM
Baulkring, best bit they're only about £7.50 each
the not so good bit is, you're going to have to remove the engine from the car, then take the gearbox off the engine and rebuild it...
#4 sonicc
sonicc
    Just On Tickover
  • 9 posts
Posted 26 July 2014 - 07:56 PM
All that for £7.50 lol any places in Essex you'd recommend?
#5 Fossy313
Fossy313
  • 583 posts
  • Local Club: Mini Club Jersey
Posted 26 July 2014 - 07:57 PM
dont rule out master cylinder or slave, all my crunching was done because of a master cylinder leaking and not allowing the required depression on the rod
Edited by Fossy313, 26 July 2014 - 07:58 PM.
#6 sonicc
sonicc
    Just On Tickover
  • 9 posts
Posted 26 July 2014 - 10:53 PM
Is there away that you can see if they are malfunctioning?
#7 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 27 July 2014 - 05:57 PM
If you have full lift on the clutch and the overthrow nuts on the shaft are touching the  boss on the clutch casing, and you dont have difficulty engaging gears or clutch drag, its as Guessworks said bulk ring/syncro, its common on 2nd gear.
#8 Cooperman
  • 23,286 posts
Posted 27 July 2014 - 05:59 PM
Can anyone remember the early 850 Minis which had syncromesh which lasted a few months if you were lucky?
We all double de-clutched them and didn't work about the syncromesh.
I guess modern drivers can't do that because they have never learned. It's not difficult and the gearbox and gear-changing is easy when you know how. It saves on a gearbox re-build.
#9 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 27 July 2014 - 07:19 PM
ah, but then they forget and take some more dog teeth off the gears and eventually they succumb to the needs of a rebuild.
#10 Cooperman
  • 23,286 posts
Posted 27 July 2014 - 07:28 PM
I learned to drive in an RAF Austin 1-ton truck which had a 'crash' gearbox with no syncros at all. That taught me how to work around the early Mini gearbox which was, effectively, a 'crash' 'box after only a short while. It also taught me how to change gear without using the clutch. Done properly double de-clutching on a gearbox with worn syncros will not cause any extra wear or damage if done properly! But, as you say, who will always do it properly?
#11 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 27 July 2014 - 08:40 PM
Must admit I'm terrible, and keep forgetting you're meant to use the clutch to change gear, and very rarely use it when I'm just pottering about. The art of matching engine speed to road speed, and as you say, the most sympathetic way of changing gears when done properly.
#12 Cooperman
  • 23,286 posts
Posted 27 July 2014 - 10:27 PM
Yes, in my 1275 'S' with SC CR gears I hardly ever use the clutch in normal road driving. In competition it's different as the gear changes are done as quickly as is possible.
#13 Pigeonto
Pigeonto
  • 973 posts
  • Local Club: ISMOC
Posted 28 July 2014 - 09:23 AM
So right Cooperman. One thing is, if you drive modern vehicles with their super slick gearboxes, you have to forget all of that and have a little mechanical sympathy when getting back in your Mini. For instance if you are slowing to a dead stop why would you need to down shift 4-3-2-1. Just use the brakes, de-clutch at the last moment or coast in neutral. The brakes are for stopping the car. That's just one example, there's loads of ways you can be kind to the box. If you must go 3rd to 2nd then 'feel' it in with light pressure for a second or 2, don't force it. Even better, double de-clutch. I'm not wearing out my baulk rings. They're a devil to replace.!!
