Cleaning A Panel - Fast Panel Wipe V. Slow Panel Wipe
11 replies to this topic
#1 rodandtom
rodandtom
  • 998 posts
Posted 27 July 2014 - 08:56 AM
Hi,
Once you rubbed it down, what's the best one of these to use to clean a panel (i am going to have to clean the whole car for respray)? What's the difference between the two?
Ta
Rod
Edited by rodandtom, 27 July 2014 - 09:03 AM.
#2 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 27 July 2014 - 09:40 AM
It's all to do with flash off times.
Panel wipe needs to be removed with a clean cloth after it is applied.
The slow one takes longer to flash off so you get more time to take it off before it dries.
The fast one tends to flash off too quickly so unless there is two of you cleaning down or you work at warp speed, then i would stick to a slow or standard one.
Especially when working in heat!
Ben
#3 mini-geek
mini-geek
  • 1,169 posts
Posted 27 July 2014 - 09:46 AM
((He beat me to it!))
One evaporates fast one takes longer.. Simples..
Basically the slow is for use in spraybooths, and in summer like now..
The fast stuff is mainly used in the workshop during cooler periods.. It's all to do with throughput really and not having to pay someone watching stuff dry.. Lol
I personally don't like the fast stuff, but some slow stuff can take too long to dry so it's a bit hit and miss..
Seeing as it's the whole car and you're not really bothered about how long it's going to take use the slow stuff...
Edited by mini-geek, 27 July 2014 - 09:47 AM.
#4 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 27 July 2014 - 09:52 AM
Don't forget, you need to wipe it dry with a clean cloth while it is still wet...
You need not stand and wait for it to dry.
I use the wax on wax off method with a wet panel wipe cloth in one hand and a dry clean one in the other when in a hurry so i am literally taking off one lot while putting more on.
But generally, you would wipe an area over with the 'wet' cloth and then go back over it before it dries with the dry.
The slow one i find is more through at degreasing too so might be a good option if it's been done in a dirty old garage! Sometimes you find that the slow leaves a film though so it's not all great news.
Try them and see what best suits you bearing in mind that fast is alcohol based and slow is white spirit based so that should give you a rough idea on evaporation times.
Ben
#5 HARBER07
HARBER07
  • 4,498 posts
  • Local Club: Naaa......
Posted 27 July 2014 - 11:07 AM
I thought the idea of panel wipe was to let it flash off. What does wiping it off achieve?
#6 mini-geek
mini-geek
  • 1,169 posts
Posted 27 July 2014 - 11:15 AM
By wiping it off you're removing the contaminants that it's absorbed..
On a side note, I actually use upol fast panel wipe.. It's not that fast though so would recomed it..
#7 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 27 July 2014 - 11:43 AM
Yup!
#8 rodandtom
rodandtom
  • 998 posts
Posted 27 July 2014 - 03:19 PM
sounds good.
Ta
Rod
#9 kezzkitkat
kezzkitkat
  • 714 posts
Posted 27 July 2014 - 07:15 PM
I agree use wipe on wipe off with two diffrent cloth also Id considered using tac rags its amazing amount of thing u pick up with it after using waterborne and solvent panel wipe
#10 rodandtom
rodandtom
  • 998 posts
Posted 27 July 2014 - 07:32 PM
tac rags?
#11 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 27 July 2014 - 07:36 PM
yeah they are sticky cloths that you wipe over the car with to collect up any dust or rubbish before painting.
They are dirt cheap (scuse the pun)
#12 kezzkitkat
kezzkitkat
  • 714 posts
Posted 28 July 2014 - 06:57 AM
^what he ssid the only thing is use It properly people tend to really force it on the panel and think it will work better dont be tempted as it could leave the resin and cause the paint to react which ive seen happen
And hahaha
