Twin Carbs For 90S Cooper
11 replies to this topic
#1 samt88
samt88
  • 445 posts
Posted 27 July 2014 - 11:16 AM
I'm looking at a set of twin carbs on eBay for a 90s rebuild cooper. How much should I pay and Is it worth it? What advantage am I likely to see? It's a 1 1/4 inch twin carb.
#2 Captain Mainwaring
Captain Mainwaring
  • 1,712 posts
  • Local Club: Surabaya Mini Club
Posted 27 July 2014 - 12:30 PM
Bit more low down puff compared to a sing HIF, but that's it.
I don't know, maybe £120-150 depending on many things
#3 Tamworthbay
Tamworthbay
  • 7,025 posts
  • Name: Clive
  • Local Club: A5 minis
Posted 27 July 2014 - 01:45 PM
Price range is very wide. A pair needing a rebuild can be had for £40ish, up to £80-£100 for a set that have been tarted up. A properly rebuilt pair that are ready to fit could easily be £200 if not a bit more on a good day. They key is to ensure they are decent. Any wear (particularly in the spindles) and they will never stay balanced.
#4 samt88
samt88
  • 445 posts
Posted 27 July 2014 - 03:08 PM
Ok cheers :) is a rebuild something I could do myself?
#5 samt88
samt88
  • 445 posts
I've taken a carb apart before but what does refreshing it involve?
#6 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 27 July 2014 - 05:42 PM
Complete strip, new spindle and bushings in the carb body, new jet assembly and needle and a new needle valve and reassembly getting the float lever set. Your biggest problem is reaming the new bushes to size when fitted, if you dont have a reamer, Don't be tembted to file them its not accurate enough. Give Burlean a ring 01722 412500
#7 HarrysMini
HarrysMini
    I do not have short legs!!!
  • 3,352 posts
Posted 27 July 2014 - 05:57 PM
I think it is worth getting them if you can get them for a decent price, I certainly wouldn't pay the £150-200 that they go for on eBay. I recently bought a pair of HS2s with manifold etc. for £50 delivered. I'm currently rebuilding them and they did need it as the spindles had a heck of a lot of play.
Give Covert on here a PM to ultrasonically clean them, that way you can be sure that the dirt isn't going to cause issues, he did mine for a really good price and they look so much better.
A comprehensive rebuild kit is around £70 and that includes pretty much everything you need.
Twins are definitely worth it though, it really depends on the rest of the engine setup, but I usually find improved throttle response and more low down torque, perhaps with the reduction of a bhp or two at the very top end. That might be a problem if you like talking horsepower at the pub, but in reality the aforementioned improvements are definitely more noticeable and useful. I won't bore you with the reasoning behind these improvements, but basically more air/fuel can get through two partially opened smaller throttles than one larger opened to the same amount.
You can improve them further by doing 'Vizard Mods' on them, which involves making them flow better.
#8 AFMike85
AFMike85
  • 127 posts
Posted 28 July 2014 - 09:58 PM
There's a 90's Cooper airbox with elbows on ebay right now for £60, but all my research says it's better to get the original cooper box
#9 mk1leg
mk1leg
  • 9,343 posts
Posted 28 July 2014 - 10:53 PM
get yourself a new set....by the time you have got a set off fleece bay and then overhauled them with all new parts new ones are cheaper.......
http://www.minispare...win.aspx?130204
#10 HarrysMini
HarrysMini
  • 3,352 posts
Posted 28 July 2014 - 11:51 PM
http://www.minispare...retors/Twin.aspx?130204
You can buy and refurbish a set of HS2s for well under £600!
Pair of carbs with manifold, heat shield and linkage - £50
Full rebuild kit - £70
Ultrasonic Cleaning - £20
= £140!
#11 timmy850
timmy850
  • 3,397 posts
  • Local Club: MITG
Posted 29 July 2014 - 03:05 AM
Yep, they fit the big oval filter and they aren't as efficient as the twin ones on the original Coopers
http://www.rsp-coope.../The_S_Pack.htm
#12 Captain Mainwaring
Captain Mainwaring
  • 1,712 posts
Posted 29 July 2014 - 07:49 AM
Not for the same CSA they can't. Simple area VS circumference calculations.   You've got that completely around the wrong way.
