Reducing Gear Ratio With Drop Gears..
5 replies to this topic
#1 mini-geek
mini-geek
  • 1,169 posts
Posted 28 July 2014 - 12:48 PM
I've currently got a 3:44 diff and a close ratio gearbox and SC drops
3:44 is fine for the road but I want to be able to lower the FD ratio for sprints..
Now I understand that I can do this by just changing the primary gear and just taking the wok and cutch off to do this..?
So if that is right I can have a 24 input and 30 idler gear on all the time, and put a 24 tooth primary gear on for the road and then change it for a 22 for track use?
Or have I got the wrong idea?
Also can anyone recommend a place to get quality drop gears?
#2 Cooperman
  • 23,326 posts
Posted 28 July 2014 - 02:33 PM
That is what SC drops were intended for, changing the ratio for different competition venues.
Mini Spares do very good quality drop gears.
#3 The Principal
The Principal
  • 763 posts
Posted 28 July 2014 - 02:50 PM
A little more complicated than you suggest, you need to remove the wok, flywheel and the flywheel housing (drain the oil, new gasket, clutch oil seal) the drop gears are between the alloy housing and the block/gearbox
Minispares sell the following sets -
22 tooth primary - 30 tooth idler - 25 tooth input = 1.136-1
24 tooth primary - 30 tooth idler - 24 tooth input = 1.0-1
23 tooth primary - 30 tooth idler - 23 tooth input = 1.0-1
24 tooth primary - 30 tooth idler - 25 tooth input = 1.0416-1
23 tooth primary - 30 tooth idler - 24 tooth input = 1.0434-1
22 tooth primary - 30 tooth idler - 23 tooth input = 1.045-1
23 tooth primary - 30 tooth idler - 25 tooth input = 1.0869-1
22 tooth primary - 30 tooth idler - 24 tooth input = 1.09-1
24 tooth primary - 30 tooth idler - 23 tooth input = 0.958-1
the gears will need shimming when swapping
#4 mini-geek
mini-geek
  • 1,169 posts
Posted 28 July 2014 - 04:18 PM
I'm confused them, why would I need to remove the idler and input if I'm keeping them the same?
#5 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 28 July 2014 - 04:22 PM
No you don't unless you are changing the input gear...
If you change a 24/24 combination to a 24/22 then the overall final drive (in 4th) will be multipled by 24/22 or 1.090909.... which will change your 3.44 to 3.76 approx.
if you ran a 24/23 then the overall final drive would be multiplied by 1.043
or
I could have just pointed you here...
http://www.guess-wor.../Tech/ratio.htm
#6 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 28 July 2014 - 04:24 PM
One other thing worth mentioning... make sure the primary gear is compatible with the ones you already have... makes a lot of noise and swarf if they arn't
