1979 Mini 1000 (Becky)
19 replies to this topic
#16 robminibcy
robminibcy
  • 1,516 posts
Posted 13 September 2014 - 04:01 PM
PicsArt_08_07_201410_37_19PM_zps04745fae
#17 robminibcy
robminibcy
  • 1,516 posts
Posted 13 September 2014 - 04:10 PM
We are now up to date! The current job is the engine. her original a series is on well over 100K and runs very nicely but is leaking oil in the words of the last mot tester "like a sieve" and hes right it is! its so bad I have to top it up neatly every time I drive it It also blue smokes very badly so its time for a rebuild. I have another a+ engine from a very kind member on here which I will drop in whilst the original is rebuilt.
Here is the A+ being picked up:
I am changing a few gaskets, the clutch and the final drive (to 3.1) before it goes in as well as painting and generally making it pretty!
More to follow!
#18 robminibcy
robminibcy
  • 1,516 posts
Posted 13 September 2014 - 04:19 PM
the engine just starting to clean strip down and wire brush:
bit cleaner
All cleaner and wire brushed back to bare metal ready for paint
Etch primed
Painted :-)
#19 robminibcy
robminibcy
  • 1,516 posts
Posted 28 September 2014 - 07:40 PM
Starting the big push to get the engine done now as I don't really fancy doing engine swaps at - temperatures!
Today got fly wheel of ready to swap to a preverto clutch. Used guessworks puller and was very easy and cooperative!
Flywheel off.
Fly wheel housing off ready to clean up and change the gasket.
#20 robminibcy
robminibcy
  • 1,516 posts
Posted 04 August 2015 - 10:02 PM
Thought it about time for an update! Nothings really happened over the last year. Shes been running and driving very well. Even the engine swap was put on hold as I kept being given old engine oil to put through her old smokey leaky engine! With the MOT looming however I think shes earned some presents!
Starting with swapping the rear right hand radius arm:
Over the next month she will be having:
Radius arm swap
Rear brake overhaul and different wheel cylinders
Full cooper S brake install (currently still on drums)
Engine swap.
Mechanically then she should be 100% :-)
