Factory Injected Engine Specs - Piston Volume Etc
6 replies to this topic
#1 rwg850
rwg850
    Starting My Mini Up
  • 4 posts
Posted 29 July 2014 - 08:11 AM
Hi guys,
Hope this is the right area for this post.
I am about to undertake a freshen up of an SPi 1275 from a 1995/6 Rover Mini.
The head is off and I am going to get that ported a bit, and I want to raise the compression ratio.
What I would like to know is the standard dish volume, so the engine builder can work out how many CC the chambers should have to get my desired CR.
I have no idea if it is a "low compression" or "high compression" engine - is there any way to check?
Any help appreciated.
Will.
#2 ACDodd
ACDodd
  • Mini Docs
  • 2,832 posts
Posted 29 July 2014 - 11:58 AM
Depending on what engine you have there are 2 types of piston fitted. Either 21962 or 21963. The 963 being the higher compression type. The dish size is the same on each pistonthe difference is the 962 piston as a 0.03" lower crown height. If you have the 962 pistons fitted it will also mean you have the sprite cam fitted. Fitting a a modified head on this engine is not going to make a massive difference unless you also fit 1.5 rockers as the cam profile is just too mild to make more power with a flowed head.
AC
#3 ACDodd
ACDodd
  • Mini Docs
  • 2,832 posts
Posted 29 July 2014 - 12:00 PM
Both pistons have an 8cc dish.
AC
#4 rwg850
rwg850
    Starting My Mini Up
  • 4 posts
Posted 30 July 2014 - 02:38 AM
Thanks for the replies AC!
I am (don't shoot me!) contemplating running the Kent 276 camshaft.
I really love the way it idles, and it will be a weekend car, as I have an R53 MCS as my daily.
The rockers will be standard (at this stage - don't want to go too crazy on my monetary outlay), and I am hoping for a CR of around 10.5/11.0:1.
Are the part numbers stamped on the pistons to identify which type they are?
It is a 12A2DJ33 engine - no idea what the J33 prefix relates to, but from my research 2D should be a high compression (9.4:1) engine.
Thanks again.
Will.
#5 ACDodd
ACDodd
  • Mini Docs
  • 2,832 posts
Posted 30 July 2014 - 04:38 PM
Keep compression to 10:1 maximum. Low compression is 9.4:1 high compression is 10.1:1.
Ac
#6 rwg850
rwg850
    Starting My Mini Up
  • 4 posts
Posted 31 July 2014 - 04:08 AM
I should mention that this engine will be using an HIF44 and be installed in my 1964 Morris 850.
It will be used as a weekender 'toy', and as such won't need the luxuries of a daily.
Is the 10:1 maximum to retain an efficient timing advance?
Will
#7 ACDodd
ACDodd
  • Mini Docs
  • 2,832 posts
Posted 31 July 2014 - 07:20 AM
Yes.
AC
