Carb Leaking Fuel From Inlet Manifold
Posted 30 July 2014 - 11:06 AM
Posted 30 July 2014 - 11:56 AM
Double check the float valve again. The valve itself has to provide a positive shut off and the float level has to be set correctly. As you already know, if the valve is not shutting properly you can pump excess fuel either out of the overflow or into the carb throat. If the valve is only leaking a tiny bit, this may be concealed at idle as fuel is being used. However, when you turn the engine off the little bit of extra fuel in the fuel lines (above the float bowls) can drain into the float bowls, overfill them, with the excess fuel coming out of the jet.
