Welding On New Jacking Points To New Inner Sill
6 replies to this topic
#1 Hendred
Hendred
  • 484 posts
  • Location: Cleobury Mortimer Nr Ludlow, Shropshire Name: John
Posted 30 July 2014 - 03:33 PM
Hi everyone,
When replacing inner sills what do you do about new jacking points?
Weld Jacking point onto inner sill before inner sill is welded on the car or after inner sill is welded on the car?
Thanks in advance
#2 woodley miniman
woodley miniman
  • 304 posts
Posted 30 July 2014 - 03:48 PM
Before fitting would be easier, just make sure you get the location right before welding into place
#3 Hendred
Hendred
  • 484 posts
Posted 30 July 2014 - 03:50 PM
That's what I thought as a bit tight, thanks for answering.
#4 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 30 July 2014 - 03:53 PM
I would fit the inner sill first and then the jacking point.
You can line it up easily enough by using some putty to 'stick' it in place.
Put some putty on the back of the jacking point, offer up the outer sill and jacking point together and push the jacking point into the putty. Then you can take the outer sill away leaving the jacking point where it needs to be.
Then all that remains is to mark where the jacking point is by scribing or drawing round it, remove the jacking point and putty and then weld it in where you marked it.
If you done it right, the outer sill will line up perfectly.
Ben
#5 Hendred
Hendred
  • 484 posts
Posted 30 July 2014 - 03:58 PM
Thanks Ben, good point about the outer sill.
#6 JonnyAlpha
JonnyAlpha
  • 2,748 posts
  • Local Club: Exmoor Minis
Posted 30 July 2014 - 05:02 PM
I test fitted my outer sill the other day and the hole for the Jacking Points seems to be way out? Was going to weld them closed anyway :-)
#7 Cooperman
  • 23,319 posts
Posted 30 July 2014 - 06:33 PM
I have always welded the inner sill in place, then positioned the jacking point using the outer sill to get the position right.
But with M-Machine now doing a combined inner & outer sill, complete with jacking point and a few inches of floor I now buy this sub-assembly as it makes life just so much easier.
