Started My Engine And This Has Just Happened!
Posted 05 August 2014 - 06:46 PM
Posted 05 August 2014 - 06:48 PM
Posted 05 August 2014 - 07:15 PM
I dont see the picture, unless its a huge cloud of pure white smoke :)
Posted 05 August 2014 - 08:03 PM
Posted 05 August 2014 - 08:09 PM
you might need a top-up there chap. oil cooler/pipe gone?
Posted 05 August 2014 - 08:17 PM
oops that happened to me once when i had a thai very hot green curry, ![]()
Posted 05 August 2014 - 08:34 PM
ohhhhh nasty
had a look yet?
looks like turbo oil drain to me.
Edited by coopdog, 05 August 2014 - 08:35 PM.
Posted 05 August 2014 - 08:55 PM
does it still run or did it stop.
Posted 06 August 2014 - 06:20 AM
Without further investigation
Posted 06 August 2014 - 06:58 AM
Posted 06 August 2014 - 02:43 PM
Posted 06 August 2014 - 02:46 PM
oil drain will pump pretty much all your all out in a very short space of time.
Posted 07 August 2014 - 01:53 AM
I know nothing about turbos so I cannot comment on the advice and suggestions above.
When you started the engine and saw the smoke, had you moved the car or was it sitting still the whole time?
An oil leak that found its way onto the exhaust pipes while standing still cannot come from too many places and frankly I cannot think of a good source for oil leaking down the back of the block.
The slope shown in the picture suggests that the leak is along the midline of the car/engine which could mean the filter came loose, the oil feed pipe from the filter head to block came loose, or perhaps the oil pressure warning switch (or gauge line) sprang a leak. For that much oil to be dumped on the pavement that fast requires pressure... unless you somehow cracked the sump and it all leaked out while parked.
Posted 07 August 2014 - 06:26 AM
