Changing From Rc40 To Fletcher
17 replies to this topic
#1 Badboytunes
Badboytunes
  • 1,615 posts
  • Local Club: MINIS Unleashed
Posted 06 August 2014 - 06:25 AM
Not really sure what section to put this, mods feel free to move..........
So, we have on our car a single box stainless RC40 which we are looking to change to a Fletcher.
Will be looking to potentially purchase the Fletcher at MITP but am wondering if they will fit onto our manifold. Im assuming ( as ours has no cat ) that the manfold/downpipe has been changed to an LCB. If so , does anyone know if the Fltecher will go straight on?
Also, we will be looking to sell the RC40 and wondered whatit might be worth. Its in mint condition all be it about 4 years old.
#2 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 06 August 2014 - 06:45 AM
think your going to have to get under the car and measure the size of the pipe after the LCB
#3 Badboytunes
Badboytunes
  • 1,615 posts
Posted 06 August 2014 - 07:21 AM
I think you might be right Bungle. I will try and get some pics up .
#4 bloke
bloke
  • 139 posts
Posted 06 August 2014 - 03:10 PM
Ironically, I have the min in at the moment for some work, and I'm changing the Fletcher exhaust over for an RC40, both stainless steel, I can't stand the noise of the Fletcher any more. Plus it's drawing too much of the 'wrong' kind of attention, if you know I what I mean.
#5 Badboytunes
Badboytunes
  • 1,615 posts
Posted 06 August 2014 - 03:31 PM
We are changing as we prefer the look of the Fletcher. Our car is noisy (ish ) anyway and only a weekend car so the noise wont be too much of an issue.
#6 Ellie
Ellie
  • 298 posts
Posted 06 August 2014 - 06:17 PM
I've got the fletcher on my 998 at the minute.
Yes it's loud, at times too loud.
And yes it often gets the wrong attention.
But, other than a long motorway drive its ok.
The drone can get a bit monotonous on a long run.
But i don't think I'll change it. Well not yet!
#7 Badboytunes
Badboytunes
  • 1,615 posts
Posted 06 August 2014 - 09:09 PM
Our car drones a bit I think its the nature of the car. After looking some vids on youtube, I think its the way forward
#8 Twincam
Twincam
  • 1,742 posts
  • Local Club: SMAG
Posted 06 August 2014 - 11:57 PM
Initially it goes, manifold (3 into 2), down pipe (2 goes into 1 along with a flexi pipe), cat which bolts up both ends followed by the two box exhaust (back box).
Check to see if you have a decat pipe or whether you have a link pipe that connects from the end of the down pipe to the RC40 - you may be able to use it again on the fletcher unless you buy a cat back system.
I'm running a decat and maniflow (single box) on mine ATM.
Edited by Twincam, 06 August 2014 - 11:57 PM.
#9 Badboytunes
Badboytunes
  • 1,615 posts
Posted 07 August 2014 - 06:03 AM
As far as I know it has an LCB with a single box RC40 attatched to it. Not sure if it has a flexi or not. I guess im going to have to get underneath and have a look :)
#10 Twincam
Twincam
  • 1,742 posts
  • Local Club: SMAG
Posted 07 August 2014 - 08:29 AM
Do you know if it is an injection LCB? (More than likely to retain the lambda sensor) you probably have a link pipe going to the rear box too.
Jump under her and have a quick peek :)
#11 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 07 August 2014 - 09:08 AM
The other side is you will loose torque and power.
#12 Twincam
Twincam
  • 1,742 posts
  • Local Club: SMAG
Posted 07 August 2014 - 10:41 AM
I was talking to Andy at ML Motorsport on the weekend - standard exhaust manifold is adequate enough (it's a 3 into 2 into 1 as standard), a decat can see an increase in fueling (but without adjusting the map which you're restricted to on an original ecu you won't see many if any gains apart from noise) and the best size exhaust is a 1"3/4.
#13 Badboytunes
Badboytunes
  • 1,615 posts
Posted 07 August 2014 - 12:10 PM
As far as i know it doesnt have a lambda sensor. ( can you remember John? )
The car is a 91 SPI. Will have a look over the weekend and see whats what.
#14 Fast Ivan
Fast Ivan
  • 2,909 posts
Posted 07 August 2014 - 12:32 PM
should have a lambda if its an spi
#15 Badboytunes
Badboytunes
  • 1,615 posts
Posted 07 August 2014 - 01:53 PM
I dont recall seeing one, that said I have not had a proper look. Where abouts on a sytem are they located? I assume it will be on the manifold or near the link pipe?
