Removing Clutch Master Cylinder
Posted 06 August 2014 - 08:31 PM
The cylinder itself is on top of the nut, and there's the throttle body, wiring and fuel pipes getting in the way. How do I get in there?
Posted 07 August 2014 - 06:37 AM
I have the same car with Air Con which clutters it up all the more, invariable I have to remove a lot of components to allow access to the part I am after which is typical on later Mini's. I am going to be doing that very same job within a few months including the slave cylinder. Apparently its best to do both together.
Posted 07 August 2014 - 11:43 AM
I remember removing the clutch slave cylinder on an MPI and a ratchet spanner proved really helpful, especially as I could only move the spanner 5 degrees at a time...
Halfords used to do a set of Imperial ratchet spanners, you may need to look a bit further afield now.
Posted 07 August 2014 - 02:07 PM
Hmm yeah, I thought about that, but my ratchet spanners are even longer than my normal ones. They seem to be 13 mm nuts incidentally.
Might need to get a stubby spanner or a weird shaped one I think!
Posted 07 August 2014 - 02:32 PM
Try and remember to clean the bolt or get a
New one and copper it up to te max! Don't do it up so tight and gasket seal for any leaks....
Another trick is to bed a spanner in the way of the cylinder...
