Low Compression Problem
engine
3 replies to this topic
#1 M-J Leaverland
M-J Leaverland
    Starting My Mini Up
  • 2 posts
Posted 07 August 2014 - 01:16 PM
Hello,
I have a MINI One 2007 with 70, 000 miles on the clock. The engine warning light came on and I've been told that it has low compression. Here are the numbers:
1 - 200
2 - 180
3 - 90
4 - 180
The garage said that it's probably a problem with the valves and that they'll have to take the head off to fix it and that it will probably cost around £700 to fix. Can anyone tell me if this is normal for a mini like this please? Has anyone else experienced anything similar? Do you have any advice for me please?
Thank you very much.
#2 Dusky
Dusky
  • 5,322 posts
Posted 07 August 2014 - 01:46 PM
If you are an experienced mechanic you can take the head of yourself and fix whatever needs to be fixed.
If not : you will need to rely on the garage.
THis difference in compression is absolutely NOT normal.
#3 M-J Leaverland
M-J Leaverland
    Starting My Mini Up
  • 2 posts
Posted 07 August 2014 - 02:53 PM
Ok, thank you for your reply; I really appreciate it.
#4 Alex_B
Alex_B
  • 4,573 posts
Posted 07 August 2014 - 03:16 PM
It could be head gasket, valves, or piston rings. Without taking the head off you can only speculate.
