Hi all . does anyone have any clever solutions to replacing the rubber cv gator without the hassle of removing the drive shaft ? It seems like a lot of work just to replace a £4 part !!
Drive Shaft / Cv Gator
Posted 08 August 2014 - 05:16 PM
Posted 08 August 2014 - 05:23 PM
Posted 08 August 2014 - 05:31 PM
There are tools that stretch it over the CV, I think this is an option, but I am not sure if some tools are better than others.
http://www.ebay.co.u...f13=80&ff14=108
Edit: Just realised you don't even want to remove the drive shaft, don't think that is an option?
Edited by firstforward, 08 August 2014 - 05:37 PM.
Posted 08 August 2014 - 05:52 PM
With these tools, it will be necessary to remove the shaft, it isnt difficult!
I just remove caliper(2bolts) the shaft nut (and split pin!)from the middle of the hub..
Then the ball joints, (one nut each)
Then cut the tie from the pot joint and pull it out!
Posted 08 August 2014 - 06:01 PM
Parkers sell the universal kits..
you have to cut it down to size and as stated has to be glued once fitted round the shaft, I got one last year as a temporary fix before I did L2B but was a right faff and the grease just gans everywhere lol!
Posted 09 August 2014 - 06:15 AM
many thanks all. just realised the reason the gator went in the first place is that the fletcher exhaust fitted last year is touching it. dont know how the hell im going to move it !!!
