Speedometer And Headlights
6 replies to this topic
#1 Dangleeballs9568
Dangleeballs9568
  • 37 posts
Posted 10 August 2014 - 07:28 PM
Hi I have a 1980 Austin Mini 998cc and yesterday the speedometer and the headlights stopped working. Does anyone have any idea what this could be? Everything else electrical is working fine apart from those.
#2 Stiggytoo
Stiggytoo
    Best Plucker?
  • 1,170 posts
  • Local Club: CCMOC
Posted 10 August 2014 - 07:35 PM
The speedo is cable driven, has it stopped registering speed or has the backlight stopped working?
#3 Dangleeballs9568
Dangleeballs9568
  • 37 posts
Posted 10 August 2014 - 07:48 PM
It has stopped registering the speed and mileage. Also backlight is not working
#4 Stiggytoo
Stiggytoo
    Best Plucker?
  • 1,170 posts
  • Local Club: CCMOC
Posted 10 August 2014 - 07:51 PM
These are two separate issues then. It's likely that the cable for the speedo has snapped so this will need replacing. The headlight issue could be down to the switch or wiring etc, but possibly a fuse.
#5 Dangleeballs9568
Dangleeballs9568
  • 37 posts
Posted 10 August 2014 - 07:56 PM
Ok thanks. I have checked the wire at the back of the speedometer and that seems fine will have to get under the car and check the rest. Would the fuse be one of the 4 in the engine?
#6 Stiggytoo
Stiggytoo
    Best Plucker?
  • 1,170 posts
  • Local Club: CCMOC
Posted 10 August 2014 - 08:23 PM
Somebody should correct me if I'm wrong but I think the dipped beam at least should not be affected by blown fuses. This is a safety feature. Saying that, previous owners could have wired them in wrong.
The speedo cable may have an internal break, which could be caused by general wear, or being routed with tight bends etc. It may even have melted on the exhaust. The best way to determine if it is broken is to detach one end and see if the inner cable will pull out.
#7 Dangleeballs9568
Dangleeballs9568
  • 37 posts
Posted 10 August 2014 - 08:32 PM
Maybe it is the wiring because it is a mess from what the previous own has done as the dipped are not working or the back lights. Indicators and hazards are working and so is brake and reverse light it is just the headlights. Ok I will try what you have recommended for the spedometer cable
