Full 1275 Mpi Cooper Engine Complete With Wiring Loom, Subframe, Rad, Ecu, Everything You Need To Swap Or Convert
2 replies to this topic
#1 dodgy weedgie
dodgy weedgie
    Starting My Mini Up
  • 3 posts
  • Local Club: ESMOC
Posted 11 August 2014 - 06:31 AM
Selling the complete running engine out my mpi 97 cooper. Good runner, box rebuilt 3 years ago. This is complete in the front subframe with brakes, shafts, rad, fan, all the ancilleraries, wiring loom, ecu, all your relays, fuel cut off, infact most of the bulkhead will be attached so you will have clips, brackets etc, 2 keyfobs, exhaust with the cat. All you need to replace your engine or if looking for a reliable modern a+ in your older mini. Its basically the front end of the car. I can separate all the bits for more but got 5 projects on the go this winter so need to create a bit of space. Engine needs a clean due to leaking rocker gasket but this supplied also.
I could put on a pallet for collection and load onto lorry if required or a van will be required.
Can also be contacted on 07849081713
Edited by dodgy weedgie, 11 August 2014 - 06:32 AM.
#2 JonnyAlpha
JonnyAlpha
  • 2,748 posts
  • Local Club: Exmoor Minis
Posted 11 August 2014 - 06:43 AM
Price?
#3 dodgy weedgie
dodgy weedgie
    Starting My Mini Up
  • 3 posts
  • Local Club: ESMOC
Posted 12 August 2014 - 11:45 PM
Sorry guys, thought i had put that down. £1200 for the whole lot. Thats the front end of the car really. Totally complete engine set up with subrame etc to go in the car.
