wheel bearing guide
1 reply to this topic
#1 1293clubby
1293clubby
  • 71 posts
Posted 26 June 2006 - 11:29 PM
does anyone have a link to a guide with pictures for fitting new wheel bearing to standard disk mini? my new bearing kit has no spacer to go between inner bearing and inner oil seal. haynes says it should be there but there was not one on the car when i took it apart and none in kit ;) .
#2 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 27 June 2006 - 05:54 AM
Correct the kit does not come with the spacer, and if the original is missing you have to guestimate where the seal should be..
