Ultimate Engine Steady & Water Leak
27 replies to this topic
#16 Leonrjohnson
Leonrjohnson
  • 166 posts
  • Local Club: MOCQ Far North
Posted 13 August 2014 - 09:00 PM
I had to modify the stay bar by cutting it and cutting treads and making a threaded sleeve so I could adjust it to fit. The original arm was from my 998 engine that mounted on the thermostat bracket differently than the 970 due to different stud orientation .
#17 rally1380
rally1380
  • 1,893 posts
Posted 13 August 2014 - 09:19 PM
I thought the bracket that bolted to the thermostat housing went on top of the alloy housing not below??
#18 GraemeC
GraemeC
  • 7,467 posts
Posted 13 August 2014 - 09:28 PM
Hang on, got confused there for a moment. The photos aren't of the offending item.
#19 danie garry
danie garry
    I love BMW minis
  • 2,296 posts
Posted 13 August 2014 - 09:39 PM
i was thinking the same, that'd bring the bracket up enough to clear everything
#20 Daniel_moody25
Daniel_moody25
  • 407 posts
Posted 13 August 2014 - 10:40 PM
I've not had a chance to do it today but I'll have a proper look tomorrow as I have the day off, as for the water leak though I remember when I last took off the door card on that side the back of the door card on the wood was all wet so I'm pretty sure there's some water coming in through there somehow
#21 rally1380
rally1380
  • 1,893 posts
Posted 14 August 2014 - 07:28 AM
So the photo isn't of the problem?
#22 Daniel_moody25
Daniel_moody25
  • 407 posts
Posted 14 August 2014 - 09:48 AM
Attached File  1408008989399.jpg   30.01K   22 downloadsAttached File  1408009014773.jpg   29.33K   28 downloads
That's what it looks like, and as you can also see there's plenty of room between the fan and the rad
#23 rally1380
rally1380
  • 1,893 posts
Posted 14 August 2014 - 09:53 AM
Do you have any spacers between the fan and the pulley?
If not then that would solve the problem i reckon.  Failing that, maybe 'modify' the termostat bracket.
#24 Daniel_moody25
Daniel_moody25
  • 407 posts
Posted 14 August 2014 - 10:07 AM
I can't quite tell by look to be honest, was going to take the rad out later and have a proper look at what's going on there
#25 coopdog
coopdog
  • 4,506 posts
Posted 14 August 2014 - 10:19 AM
just cut the brackettttttttttttttttttttttttttttttttttttttttttttttt
#26 DannyTip
DannyTip
  • 1,020 posts
  • Local Club: A Series Magpies
Posted 14 August 2014 - 01:04 PM
Your fan is missing the spacer (http://minispares.co...fan spacer.aspx) it should sit much deeper into the radiator/fan cowling than it does in the pictures.  It would fix your clearance issue and improve cooling. Oh and it would be less likely to take your fingers off.
#27 Daniel_moody25
Daniel_moody25
  • 407 posts
Posted 14 August 2014 - 06:08 PM
Found a spare spacer on the engine Sat in my garden so I took it off put it on my car and steady went in perfectly fine
#28 DannyTip
DannyTip
  • 1,020 posts
Posted 17 August 2014 - 10:12 PM
Glad you got it sorted :)
