Brake Switch Mot Fail?
Posted 16 August 2014 - 06:35 AM
Posted 16 August 2014 - 06:43 AM
A warning light for low fluid needs to stay for MOT, and the switch just tests the bulb. If you can find another way to do this, then you could fit a fan switch in this location.
Posted 16 August 2014 - 07:31 AM
Posted 16 August 2014 - 07:40 AM
Does make me wonder how mine had a full mot when I bought it and the switch wasn't even wired up!
Because it wasn't tested correctly.
Posted 16 August 2014 - 09:05 AM
Posted 16 August 2014 - 10:13 AM
Same… makes me wonder where some people take there cars… Our switch doesn't work, Car hardly ran, Fueling was WAY too rich (Off the scale on the Gunson!!!) Tyre edge was worn right down, headlights set too high yet was sold with full years MOT!….
Posted 16 August 2014 - 10:29 AM
I replaced that switch with one for an electric fan on one of my Minis a couple months ago and it passed it's MOT no problem.
Go and ask your tester.
Edited by Tupers, 16 August 2014 - 10:29 AM.
Posted 16 August 2014 - 10:31 AM
it works like this - bloke in pub 'I need an mot', other bloke 'no probs £50 mate'. They are clamping down a lot but the there are still some dodgy people out there. That's assuming that it isn't a forgery but that's much harder with the database system they have been using for a few years.Does make me wonder how mine had a full mot when I bought it and the switch wasn't even wired up!
Posted 16 August 2014 - 10:40 AM
I have never seen an mot tester even look near this switch
Posted 16 August 2014 - 11:18 AM
I am on Mini number 5, they have never pressed it and it is totally pointless anyway. The spade is broken off the resevoir cap on mine yet the lamp still works as normal, I presume the float switch is wired as normally open which is a design fail rather than an MOT fail IMO, Lol
Posted 16 August 2014 - 01:58 PM
Posted 16 August 2014 - 02:21 PM
If you ran you auxiliary fan off the test switch, via a latching relay, it wouldn't be an issue - or you cloud replace it with a handbrake switch and separate warning light, like on other cars.
Posted 16 August 2014 - 02:25 PM
Why not just fit the thermostat anyway?
Posted 16 August 2014 - 02:35 PM
You know a car run in the UK without a thermostat takes longer to warm up and may not reach optimum running temperature? and if its not running hot enough this can lead to increased engine wear and poor mpg. I'd just run a thermostat
Posted 16 August 2014 - 02:40 PM
