Brake Switch Mot Fail?
#16
Posted 16 August 2014 - 03:25 PM
#17
Posted 16 August 2014 - 04:09 PM
My brake level test light works fine - yep - I'm showing off ![]()
why not put the switch where the fog light is (under o/s parcel shelf)
If you have a fog light ?
and yes the brake fluid cap is always falling apart
Edited by sledgehammer, 16 August 2014 - 04:12 PM.
#18
Posted 16 August 2014 - 05:42 PM
#19
Posted 16 August 2014 - 05:46 PM
#20
Posted 16 August 2014 - 05:52 PM
#21
Posted 16 August 2014 - 06:01 PM
If you want it for 'spirited' driving then wire a switch in that jumps the thermostat switch instead but leave the feed as one switched with the ignition, that is how the proper period kenlowe ones are too, you could use a fog light switch and have the lamp wired so it reminds you that it is on and also the electrical backfeed will make the lamp illuminate when it comes on in auto mode via the stat so you can see it has been triggered and compare the water temp to fine tune the stat setting. Are you removing the fixed fan?
Eventually, I will fit a thermic switch. But in the meantime, an illuminated switch is how I will do it, but I plan on making a new dash next year with a fan switch and warning light installed in this as well as the thermic one, I just like a bit extra control! Then, as you say, the thermic switch will light up the warning light on the dash also. I am keeping the fixed fan, the electric one is just for heavy traffic.
#22
Posted 16 August 2014 - 06:03 PM
I don't know why you wouldn't want the fluid level light working, I think it would be quite useful to know if you've had a sudden loss of fluid. Hardly pointless at all.
Regarding the light, what you can do is fit a switch to the handbrake and buy a brake warning light from CBS and wire it up to the cap, this would do exactly the same thing without taking up a switch space. You can also buy a switch with a fan logo on from CBS.
And I am fairly sure the brake fluid level light is an MoT item, just many testers probably don't know the Mini has one.
#23
Posted 16 August 2014 - 06:26 PM
#24
Posted 16 August 2014 - 06:47 PM
my cap has a terminal broke like so many others but still the red light does not come on, it does if you press the test button so im fairly sure they are fairly useless, lolI don't know why you wouldn't want the fluid level light working, I think it would be quite useful to know if you've had a sudden loss of fluid. Hardly pointless at all.
#25
Posted 16 August 2014 - 06:59 PM
#26
Posted 16 August 2014 - 07:16 PM
#27
Posted 17 August 2014 - 01:54 PM
Without the switch you cant check that the bulb works to prove how useless it is if the wires fall or break off, has anyone ever had it actually come on due to low fluid?, lol
yes when bleeding the system
can be useful for that (when it's working)
#28
Posted 17 August 2014 - 02:12 PM
You can if you put a switch on the handbrake, which replaces the dash switch. Nearly every modern car has exactly this.
#29
Posted 17 August 2014 - 02:26 PM
Thread hijack alert ...
lights I would like to see - would be on the brake lights - so I know they are working
is it a requirement for the brake lights to work with ignition off now ? as they do on most new cars ?
hijack over ...
#30
Posted 17 August 2014 - 02:48 PM
My cap is always off when bleeding the system?Without the switch you cant check that the bulb works to prove how useless it is if the wires fall or break off, has anyone ever had it actually come on due to low fluid?, lol
