Headlining. Glue Or Clips
12 replies to this topic
#1 MrElliott
MrElliott
  • 419 posts
  • Local Club: Box Hill Mini Club
Posted 16 August 2014 - 05:54 PM
so im having to put a new headlining on my mini when i get it back in a month or so. should i attach it to the seams with clips or just use glue? its just using glue gets soo messy :/
cheers
Elliott
#2 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 16 August 2014 - 07:06 PM
Both, use small bulldog clips ( lots of them )  to position it and then impact adhesive to permanently fix.
#3 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 16 August 2014 - 07:23 PM
Double sided tape is easier.
#4 MrElliott
MrElliott
  • 419 posts
Posted 16 August 2014 - 07:37 PM
double sided tape sound like a good idea. but by clips i mean these....
http://www.minispare...94.aspx|Back to
#5 leepol83
leepol83
  • 1,744 posts
Posted 16 August 2014 - 08:06 PM
I've done mine with evo stick (don't get the solvent free it's terrible ) once you get started with it it's brilliant and really does stick well I've heard of double sided tape but I'm not convinced it'll hold as I really had to pull mine about to get it tought and crinkle free,my advice would be to take you're time and don't rush it walk away if you need to and I'm sure you will need to ha ha!!!
#6 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 16 August 2014 - 10:43 PM
The factory used tape from the mid '90s on and it's been fine on my car since I fitted it 14 years ago too. The glass seals hold the headliner, whatever you stick it with only needs to hold it while you align everything and get the seals in. You use the bulldog clips while tensioning it and the wrinkles shrink out with heating.
The small trim clips you linked above are for holding various boards and panels. I don't remember there being any around the actual headliner but they do hold the C pillar panels, lower dash rail trim and so on.
#7 grahama
grahama
  • 2,442 posts
Posted 17 August 2014 - 09:46 AM
What strength double sided tape did you use Dan??
#8 midridge2
midridge2
  • 1,794 posts
Posted 17 August 2014 - 11:52 AM
Its more like a double sided sellotape so very thin.
#9 HarrysMini
HarrysMini
    I do not have short legs!!!
  • 3,352 posts
Posted 17 August 2014 - 12:44 PM
The only stuff I've used barely holds a piece of paper up. I've heard 3M make some really heavy duty stuff though.
#10 alex-95
alex-95
    I am THE CLAMP MAKER
  • 6,042 posts
Posted 17 August 2014 - 02:56 PM
I used mamouth double sided tape by everbuild to stick my door cards together which is good also the double sided for carpet and flooring is very strong.
#11 midridge2
midridge2
  • 1,794 posts
Posted 17 August 2014 - 03:24 PM
I have used it many times to stick mini head cloth in place, it, as Dan said used by rover in the 90s.
#12 MrElliott
MrElliott
  • 419 posts
Posted 17 August 2014 - 06:52 PM
Thats ut then. Double sided tape is the way forward :)
#13 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 17 August 2014 - 08:52 PM
Exactly, just some double sided from B&Q or somewhere. As I said, if the lining is fitted right the tape isn't doing much at all. Carpet tape or similar would be way over the top and too wide. If you use something really strong it will pull the paint off as you make adjustments.
Edited by Dan, 17 August 2014 - 08:55 PM.
