Hi all..
Im in the middle of putting things back together on my engine but need a bit on info on a few things please...
First, I am fitting a new clutch kit while its apart... how do I change the thrust bearing? Its a non verto early type... Do I need to press off and on again?
Second, which way does the oil slinger ring go on the crank? Its something I failed to pay attention to when I was stripping it... Just want to be sure before I put the timing cover back on... its a 1275 with a double row chain and gears... not sure if that makes any difference...
