Drive Flange Torque
8 replies to this topic
#1 maccers
maccers
  • 1,876 posts
  • Local Club: LSMOC
Posted 20 August 2014 - 04:55 PM
Am fitting cooper s disc brakes, Haynes Manual suggests 57 nm for the drive flange to disc brake screws. Seems a bit extreme?
#2 HarrysMini
HarrysMini
    I do not have short legs!!!
  • 3,352 posts
Posted 20 August 2014 - 05:04 PM
Sounds about right to me.
#3 TrboDieselPwrd
TrboDieselPwrd
    Just On Tickover
  • 5 posts
Posted 20 August 2014 - 05:43 PM
I question this as well since it's quite difficult to apply 57nm (~40 ft-lbs?) of torque with a posidrive screwdriver.  Sure enough that's the spec, so would a posidrive bit into a torque wrench be the right way to go about doing this?
I'm afraid of possibly stripping the screw so I've got them in there as tight as I could manage by hand.
#4 Gremlin
Gremlin
  • 2,142 posts
Posted 20 August 2014 - 06:11 PM
Think 2 things are being talked about, harrysmini is right, you might be thinking of the drum screws turbodiesel, the drive flange bolts are about 5/8 af not posi screws
#5 the.stroker
the.stroker
    TMF Admin
  • 4,348 posts
  • Name: Dan
Posted 20 August 2014 - 06:22 PM
Cooper S brakes use screws instead of bolts to hold the drive flange to the disc assy
#6 the.stroker
the.stroker
    TMF Admin
  • 4,348 posts
  • Name: Dan
Posted 20 August 2014 - 06:28 PM
SF604051
SCREW DRIVE FLANGE COOPER S
Countersunk crosshead screw. 1/4"unf / 16mm(3/8") total length.
To hold the drive flange to the brake disc on the Cooper S type 7.5" wide brake set up. Also holds striker plate for door.
£0.23 exc vat
£0.28 inc vat
( Taken from the minispares website )
#7 A-Cell
A-Cell
  • 1,610 posts
Posted 20 August 2014 - 06:59 PM
Assuming this 1/4in UNF screw is grade S, then 10 ft-lb or 13 Nm torque. The 57Nm refers to the 3/8in drive flange bolt on the 8.4 inch disc for the 12 inch wheel.
#8 TrboDieselPwrd
TrboDieselPwrd
    Just On Tickover
  • 5 posts
Posted 20 August 2014 - 08:33 PM
I think there is some confusion going all around here, including on my part...
The OP mentions Cooper 'S' brakes which I interpret as 7.5" with the 4 countersunk posidrive screws (which are similar to drum screws) holding the disc to the drive flange.  The larger 8.4" (or other?) discs I assume have bolts where the larger torque numbers are applied.
10 - 15 ft-lbs for the Cooper S screws sounds right.  My (and perhaps others') confusion stems from the Haynes manual, which states only a single torque value (57 Nm) for disc to drive flange screws.
Thanks for all of the clarifications!
#9 maccers
maccers
  • 1,876 posts
  • Local Club: LSMOC
Posted 21 August 2014 - 04:14 PM
Hi all, yes it was the posi drive type screw, formerly I only done them wrench tight for fear of not being able to undo them easily. I guess the 57 nm is for the larger discs.
