Radius Arms
16 replies to this topic
#1 Tobyrm1
Tobyrm1
  • 79 posts
Posted 21 August 2014 - 04:15 PM
Hi All,
Just rebuilding my subframe after a paint.  Have fitted the radius arms and torqued them up.  Am wondering how much stiffness there should be with moving the arm up and down? It can be moved up and down relatively easily but will not fall under it own weight.  Just wanted to check whether that was normal?
Also, is there any easy way to reattach the radius arm mounting bracket? Cant get a socket on the bottom bolt that faces the heel board!
#2 Fossy313
Fossy313
  • 583 posts
  • Local Club: Mini Club Jersey
Posted 22 August 2014 - 09:22 AM
in my experience theres something not right there, i have just rebuilt a radius arm and although they are heavy move very freely under their own weight.....sound to be like the bushes or bearings have not been remmed out correctly and the spindle is stiff....have you tried greasing....
you should be able to get a 3/8th socket in if you lift the radius arm up to get it in.....im pretty sure thats how i did it.
#3 JonnyAlpha
JonnyAlpha
  • 2,749 posts
  • Local Club: Exmoor Minis
Posted 22 August 2014 - 09:55 AM
What's the Torque setting for Radius Arms?
When I dismantled my Subframe and Radius Arms I too struggled with the same bolt even though my Subby was out!! In the end I found a different profile socket that fitted.
Try it without the Rear Shock attached, you may be able to lift the Radius Arm more without it fitted?
#4 Tobyrm1
Tobyrm1
  • 79 posts
Posted 22 August 2014 - 11:57 AM
The rear shock isn't attached. I torqued it up to 72nm which is what the rover manual I've got says.
I pumped it full of grease so can't think its that, it might be normal I don't know!
#5 Fossy313
Fossy313
  • 583 posts
Posted 22 August 2014 - 03:49 PM
Put it this way both my radius arms if I undo the shocks i have a jack underneath supported with a block of wood because if you just loosened the shock they would crash down to the floor.
#6 Tobyrm1
Tobyrm1
  • 79 posts
Posted 22 August 2014 - 06:28 PM
This one definitely doesn't do that. I'm led to believe they are reconditioned so maybe as they wear they become freer?!
#7 stocky
stocky
  • 338 posts
Posted 22 August 2014 - 07:21 PM
You may want to take them back to who ever reconditioned them as I have just fitted recon'd radius to mine and they drop freely.
Are both arms the same?
#8 Tobyrm1
Tobyrm1
  • 79 posts
Posted 22 August 2014 - 08:01 PM
I bought the shell with reconditioned subframes so would have thought they would have been done.
I have not reattached the other arm yet. Wanted to know if this was normal!
#9 Tobyrm1
Tobyrm1
  • 79 posts
Posted 23 August 2014 - 07:12 AM
Does anybody on here rebuild the radius arm pivots?
#10 carbon
carbon
  • 2,590 posts
Posted 23 August 2014 - 04:28 PM
Toby - a rebuilt radius arm should 'fall' under its own weight, if it does not there is something amiss.
Try loosening off the outside 1/2'' UNF nut, but leave the inside one clamped, and see if this makes any difference.
If this frees it up then it is not the radius axle tight in the radius arm..
#11 Tobyrm1
Tobyrm1
  • 79 posts
Posted 23 August 2014 - 04:43 PM
Hi,
Thanks for your reply.
I have loosened off the outside nut. It is freer like this but as you move the arm up and down the nut spins around. On the thread on the inside and the outside.
Don't know what this means.
#12 carbon
carbon
  • 2,590 posts
Posted 23 August 2014 - 06:29 PM
Means the radius arm pin is probably too tight in the radius arm.
If you tighten up the inside 1/2'' nut so it does not turn with the radius arm and it is stiff then suggest you need to take the arm out and check the fit of the pin inside the arm. Should be a nice sliding fit, not tight.
#13 Tobyrm1
Tobyrm1
  • 79 posts
Posted 25 August 2014 - 02:01 PM
Hi,
Have taken the radius arm back off. Have removed the thrust washers and the dust seals, tried to move the pin and it is solid, wont slide out or turn.
Does this mean I need reconditioned radius arms?
#14 Vipernoir
Vipernoir
  • 782 posts
  • Local Club: Minis Unlimited
Posted 25 August 2014 - 03:07 PM
I would suspect that the bush hasn't been line-reamed with the bearing.
Probably done by hand without use of the proper tooling.
I'm just down the road from you (relatively) and can take a look if you want, as I'm tooled up to do them properly.
#15 Fossy313
Fossy313
  • 583 posts
Posted 25 August 2014 - 03:50 PM
take vipers help mate, at the end of the day with his help you may only need a radius arm repair kit :)
