If you want to know more it is all detailed in this very interesting book.......but no mention of a 1081cc
The A-Series Engine - Its First Sixty Years
by Graham Robson
Published 20/10/2011 by Haynes
1962 - 1970 = all A-Series 'S' type engines were produced at the Morris Engine Plant at Court House Green in north of Coventry = production of all 970, 1071 and 1275cc S engines as designed by Eddie Maher & John Cooper (& early Midget/Sprite 1275cc engines) and the short lived A-Series Diesel.
(All 'S' versions of 1275 engine continued manufacture at Morris Court House Green, Coventry until the end of production in 1970's)
Mainstream A-series production was at Longbridge, East Works producing 848, 998, 1098cc and which could build up to 12,000 engines and transmissions every week for the Mini and 1100 ranges with the ability to also make in-line engines for Midget, Sprite, Minor, A40, etc.
In 1968 East Works also started producing the 1275 non 'S' versions of A-Series for mainstream mass production.
There are also pictures of BL's OHC A-Series engine for the Mini in 1975 which had a 1097cc version, see below.
They featured belt drive to the overhead camshaft, single or twin-SU carbrettors and retained all the familiar A-Series features, such as the starter motor, alternator, distributor and spark plugs on the same forward facing side of the original cylinder block. There were also inline versions developed for BL's rear wheel drive cars. 11 prototypes of all sizes were built and completed 3,200 hours on test beds and 2,200 vehicle miles.
The 1275cc OHC A-Series produced 84bhp @ 6750, torque 80lb/ft @ 4,500 (against 59bhp @ 5300, torque 69lb/ft @ 3000 for the pushrod engine) in standard form.
There were also 970cc and 1097cc versions produced and tested but the project was eventually canceled due to the mounting losses of British Leyland which had become nationalised during the engines development.
