Vacuum Advance Tube Diameter
Posted 23 August 2014 - 10:24 AM
Does it matter wich diameter of tube I use for my vacuum advance?
Posted 23 August 2014 - 10:35 AM
Posted 23 August 2014 - 10:56 AM
Posted 23 August 2014 - 11:11 AM
Yes and no. You don't want tubing with a tiny, microscopic bore as it will limit how fast the distributor can respond. However, too large will just look silly. The original tubing will be close to 1/8" (3mm) outside diameter and have a bore of about 2mm. Your larger tubing will work... it will just look different and you are likely to need adapters to fit the carb and distributor.
Posted 23 August 2014 - 11:52 AM
Posted 23 August 2014 - 12:36 PM
Posted 23 August 2014 - 12:42 PM
cheers
