hey guys.. how't it going? I would like to inquire as to the tappet Gap on my 998 A+ engine.. the only catch is that im using a 1098 camshaft.. now does this make a difference or do i still set them all to 12 thou/30mm? Any advise would be greatly appreciated.. thank you!
Tappet Clearance Question.
Best Answer Cooperman , 24 August 2014 - 07:42 PM
12 thou is really fine for all Mini engines unless running 1.5:1 rockers.
The reason for the gap is to prevent the valves failing to close due to expansion when hot. In fact, for a Mini valve to expand enough to close up a 12 thou gap would require a temperature at which the engine would have already seized up. I can't be bothered to do the calculations, but it will be fine at 12 thou for both inlet 7 exhaust. The cam is of no consequence here.
Go to the full post
Posted 24 August 2014 - 10:59 AM
Posted 24 August 2014 - 11:15 AM
Different people have different opinions, but I set mine to 12 thou inlet and 15 thou exhaust.
Someone will have to confirm whether or not the cam will make any difference.
Posted 24 August 2014 - 12:13 PM
thanks for the reply.. i thought the 12 thou and 15 thou was for the 1275 and metros?
Posted 24 August 2014 - 07:42 PM Best Answer
Posted 24 August 2014 - 07:50 PM
Posted 24 August 2014 - 08:05 PM
I set 0.015" in and ex on my 1310 cc 'S' with 1.5 rockers and have never had any problems.
Posted 24 August 2014 - 09:06 PM
Posted 24 August 2014 - 09:22 PM
No, 15thou is not correct. You want 0.012" inlet and 0.015" exhaust.
Posted 24 August 2014 - 09:33 PM
ok, cheers bud.No, 15thou is not correct. You want 0.012" inlet and 0.015" exhaust.
Posted 25 August 2014 - 04:33 AM
thanks for all the replies.. that cleared it all up.. and thanks Cooperman :)
Posted 25 August 2014 - 09:56 AM
Cheers dude.
