How Do You Tighten Up A Sloppy Gear Change.....
8 replies to this topic
#1 exuptoy
exuptoy
  • 674 posts
Posted 25 August 2014 - 04:40 PM
......on a 96 1275 Sprite? I'm fed up of finding 1st instead of third and my change is sloppy. Any way to replace any bits which will make some difference?
#2 Stiggytoo
Stiggytoo
    Best Plucker?
  • 1,170 posts
  • Local Club: CCMOC
Posted 25 August 2014 - 05:02 PM
I've never had the problem of selecting the wrong gear. But generally the roll pins (two of them) in the linkage tend to wear and you will be able to see the play when you wiggle the gear stick. May be other areas to check.
#3 Dusky
Dusky
  • 5,322 posts
Posted 25 August 2014 - 05:49 PM
Does it have a quickshift fitted?
#4 exuptoy
exuptoy
  • 674 posts
Posted 25 August 2014 - 06:07 PM
No, standard. Just noticed that slick change thing in minispares which supposedly keeps the shift over at the 3rd/4th change gate. Anyone tried one.
#5 Stiggytoo
Stiggytoo
    Best Plucker?
  • 1,170 posts
  • Local Club: CCMOC
Posted 25 August 2014 - 07:14 PM
It think you should first sort out the underlying issue of the play. The gears are very far apart on a mini so it should be very hard to select the wrong gear.
#6 exuptoy
exuptoy
  • 674 posts
Posted 25 August 2014 - 08:04 PM
It won't go into 1st, it just crunches. If I take my time shifting it's fine, but as you say there is such a throw across the gate to 3rd I have a habit of catching 1st. That bias thing from minispares is here
http://www.minispare...px|Back to shop
I'd still like to tighten the slop though.
Edited by exuptoy, 25 August 2014 - 08:05 PM.
#7 exuptoy
exuptoy
  • 674 posts
Posted 25 August 2014 - 08:07 PM
What about the ball and cup etc do they wear?
#8 Badboytunes
Badboytunes
  • 1,615 posts
  • Local Club: MINIS Unleashed
Posted 25 August 2014 - 09:04 PM
I had a quick shift fitted until recently. The gate was super close, felt really good. Bit getting into 1st felt a bit notchy at times. So this has been replaced with a standard lever and its like stirring porridge in comparison lol. However, it goes into gear really easily now.
Perhaps you have an underlying issue.?
Edited by Badboytunes, 25 August 2014 - 09:05 PM.
#9 exuptoy
exuptoy
  • 674 posts
Posted 25 August 2014 - 10:42 PM
I'm gonna fit a braided line to the clutch slave to cure the crunch I have in first anyway then bleed it all up and then take a close look at all parts of the shift. Cheers for any advice.
Edited by exuptoy, 25 August 2014 - 10:43 PM.
