1988 Mini Pops Out Of 4Th Gear Constantly - Need Help (Mini Nooby)
1 reply to this topic
#1 mungomini
mungomini
    Starting My Mini Up
  • 2 posts
Posted 25 August 2014 - 06:49 PM
Hello everyone.
I own a 1988 mini that I absolutely love and bought from a private party approximately 3yrs ago.  Up until now, I have had very little problems other than standard leaks and routine maint.  In fact, I have only recently started experiencing some gearbox is issues where first 2nd and 4th were popping out of gear.
Background:
I bought the car from an individual that converted it from automatic to 4-speed.  I've only put about 1,000 miles on it as I've mainly been been using it as a weekend run about, and rarely above 50mph.
Recently I decided to take my bonus check and treat her to a visit to the shop to fix some leaks and other issues I had been concerned about.  Replaced Water pump, Radiator and Oil seepage from the shifter etc.
During the work the technician (highly reputable European specialist, but not a classic Mini expert) noticed that the engine mount bolts were really loose and that the engine was hitting the fire wall during the drive - OK, this is my first and only mini so I wouldn't have known the difference.  I asked him to make it right and he did.
I picked up the car and was Happy as pie with the feel and the repairs made.  Unfortunately, it appears that my investment opened up pandora's box.
I didn't make it more than 5 miles down the road and had to return the car for another look.  The car's gears were gritty and the car was popping out of 2nd and 4th gear.  More so in 4th during deceleration when I let off the gas.
I returned the car and the technician looked it over again.  He loosened the engine bolts just a bit thinking the new regidity may be the cause and also replaced what appeared to be a worn shifter bushing.  The car doesn't pop out of 2nd now and the shift into all gears is smooth, but It still pops out of 4th during deceleration / letting off the gas.
Wanted to send a shout out to see if you guys thought tightening the engine mounts may have brought to light a problem the previous owner had, but has masked it by loosing bolts as opposed to trouble shooting the problem.   I know very little about mini's and need some help with my baby.
I can't think of anything else that would have changed that would have literally brought this problem on overnight.
#2 Alex_B
Alex_B
  • 4,573 posts
Posted 25 August 2014 - 06:53 PM
Sounds like the shift mech is being forced out when the engine moves under deceleration, I would be looking at the lower engine mounts for wear, as well as the concertina rubber around the shift mech shaft on the gearbox. Both those could be causing undue movement by the engine which is in turn knocking it out of gear. The latter could be the rubber has gone hard and is putting pressure on the shaft preventing it from staying engaged in 2nd and 4th
