Mini Cooper 1275 Mpi Engine Complete, Everything Required, Possible Project
3 replies to this topic
#1 dodgy weedgie
dodgy weedgie
    Starting My Mini Up
  • 3 posts
  • Local Club: ESMOC
Posted 28 August 2014 - 07:53 AM
I am selling a Complete running MPI Cooper engine. This is essentially the front of an MPI. What you get will depend on the price as i could offer a project to go with it or everthing is there To MPI your existing mini if looking for a reliable engine.
Complete engine set up, engine(running,95000 approx have mot to prove) box was rebuilt 2 years ago, needs rocker gasket, ecu (2 fobs) full wiring loom, rad, fan, air filter, all conections, ignition switch, battery cable, Alternator, starter, fuse boxes, relays, You name it theres including most of the bulkhead if required and the front subframe also. As well as the fuel tank and fuel lines and exhaust. £1000. Delivered on a pallet any where in the uk(not sure about northern ireland) FREE! Yes FREE!
Extras that can be added to the above (same postage)
MPI sevro and pedal box with throttle £100
Steering rack £30 non Sportspack, £50 for Sportspack one.
8.4" hubs, good discs and pads calipers etc with shafts £100
I also have Have a bare shell needing welding to the front drivers side, flinch,door post, A panel wing and could probably do with a front panel corner. The rest of car is solid, its been patched over the years and has lost its rear seat and bins as had a cage fitted. I was going to use this shell to reshell either the MPI i had as it was rotten, or a rotten spi i have (only front subframe left) and have a cuŕrent v5 in my name. The shell has a good rear subframe attached. £400 for the shell. I also have all the glass etc if required for extra. This will be collection only. Or everything above £1500 again collection only. The shell will go in a luton van, easier with tail lift. Or a long wheel base transit or Merc sprinter. May consider paypal, but cash or bank transfer fine.
best to get me on my mobile 07849 081713
Keith
Edited by dodgy weedgie, 14 September 2014 - 10:30 AM.
#2 silve1999
silve1999
  • 1,146 posts
  • Local Club: MiniFreakz, Brighton Mini Club
Posted 28 August 2014 - 09:00 AM
do you have pictures of the shell? is the engine in the shell?
#3 dodgy weedgie
dodgy weedgie
    Starting My Mini Up
  • 3 posts
  • Local Club: ESMOC
Posted 28 August 2014 - 03:20 PM
No, the engine is separate from the shell. I have no intention of putting it in. I have far to many projects as is and no time to do that. The reason i said about the shell as its for sale seperate and just thought someone might want to Turn it into a bit of a project. The shell is bare bare the subframe and i might leave the steering column and key in it. If you text me i will send pics to your phone or give me your email address.
#4 dodgy weedgie
dodgy weedgie
    Starting My Mini Up
  • 3 posts
  • Local Club: ESMOC
Posted 14 September 2014 - 08:20 AM
Bump
