Mpi Locations Of Crank Sensor And Camshaft Sensors?
8 replies to this topic
#1 electricfurnace
electricfurnace
  • 143 posts
Posted 28 August 2014 - 10:16 PM
Got new ones ready to fit but cant work out where they are? Anyone got any guidance or a pic of where each sensor is on the mpi engine?:) cheers
Edited by electricfurnace, 28 August 2014 - 10:17 PM.
#2 Tupers
Tupers
  • 4,156 posts
Posted 28 August 2014 - 10:40 PM
The crank shaft sensor actually reads off the flywheel and is located down by the starter motor. The cam sensor is at the back of the engine on the passenger side were the mechanical fuel pump would be on an earlier Mini.
#3 electricfurnace
electricfurnace
  • 143 posts
Posted 29 August 2014 - 07:26 AM
Ok cheers mate, are they easy to change in situ?
#4 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 29 August 2014 - 09:37 AM
Can be done, but there's not a lot of room round the back to get to the cam sensor.
#5 electricfurnace
electricfurnace
  • 143 posts
Posted 29 August 2014 - 07:12 PM
Is it able to be reached from above and reaching round rather than having to have car on ramps?
Is it grill off for crank sensor?
#6 dbcool20
dbcool20
  • 91 posts
Posted 29 August 2014 - 07:50 PM
Crank sensor can be done without removing the grill, and cam sensor can be done from above, its just a hassle because there is really not much room to access the sensors as Guessworks said above.  ;D
#7 electricfurnace
electricfurnace
  • 143 posts
Posted 29 August 2014 - 08:00 PM
Only had a quick look earlier as it was raining but crank sensor plug looked buried against grill by starter, if im looking at the correct thing. didnt look like any room, was hoping to avoid taking grill off as its riveted on :s
#8 dbcool20
dbcool20
  • 91 posts
Posted 29 August 2014 - 08:04 PM
Its a pain (like almost every thing in the Mini engine bay) but can be done.
#9 electricfurnace
electricfurnace
  • 143 posts
Posted 02 September 2014 - 10:28 AM
Crank sensor looks do-able.
Can't see how to do the camshaft sensor from above though!
