I always do appreciate your posts. It's often not the easiest thing in the world to get a properly thought out answer.
Okay good to know, I'm learning lots here. Yes as you can imagine as my splines appear in good condition and other than the fact my rack is missing one nylon bushing, I really don't want to go through all the trouble of buying a rack if there is any possible way around.
What worries me is why this bushing is missing (along with the seal and circlip), surely someone will have to have taken the ball joints off on that side previously. So either way I would like to make sure it has been put back correctly. As I understand it the ball socket threads into the rest of the rack.
I may try and contact Keith Calver as you said. It may be interesting to hear if he has any other pearls of wisdom on the subject.
I understand why the rack servicing is a dark area as you mentioned. Why not just replace if you live in the USA or UK. Makes total sense. But unfortunately living on a little Island in the Caribbean I often come across projects where I have to make do with what I can find. What is often referred to here as 'Island Engineering'; which I now understand after studying engineering in the UK for two years is a term used extremely loosely! But sometimes people do come up with some amazing solutions.
How would you suggest being able to re-install the ball joints, surely some red loctite would ensure it never came loose again?
Thanks again
Toby
