Cost To Replace A Clutch Oil Seal?
10 replies to this topic
#1 Bell-nose
Bell-nose
  • 137 posts
Posted 31 August 2014 - 07:16 PM
Hi can anyone provide an indication as to how much to pay for the clutch oil seal to be replaced? - i have done it recently and it leaks so i would rather pay for it to be done.
Thanks,
#2 Stiggytoo
Stiggytoo
    Best Plucker?
  • 1,170 posts
  • Local Club: CCMOC
Posted 31 August 2014 - 07:44 PM
3 or 4 hours of labour? You may want to consider changing the clutch plate if you haven't already.
#3 Gremlin
Gremlin
  • 2,142 posts
Posted 31 August 2014 - 07:57 PM
The Minispares uprated oil seal is very good, if you do get someone else to do it make sure they know mini's and supply a Minispares uprated seal, in theory the flywheel shouldn't be too difficult to get off because you just had it off
#4 Gr4h4m
Gr4h4m
  • 1,802 posts
  • Local Club: Club less.....
Posted 31 August 2014 - 08:46 PM
Remember its not always the seal, the primary gear might it worn. Or the seal damaged when installing it. The seal installation tool helps keep it square when installing it.
I have always had better luck with the double edged black seal
#5 Gremlin
Gremlin
  • 2,142 posts
Posted 31 August 2014 - 08:48 PM
Could be the primary gear bushes as well, what sort of crank case ventilation are you running, could just be excessive pressure
#6 Bell-nose
Bell-nose
  • 137 posts
Posted 01 September 2014 - 08:13 PM
thanks i will send it in to my local mini specialist - its an mpi so standard i believe. I will ask them to change the primary gear bush while they are at it.
#7 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 01 September 2014 - 08:20 PM
Changing the primary gear bush will be beyond a lot of garages, even mini specialists, unless they have access to a machinist with a lathe....
The Rover book time for replacing the rear seal ( or clutch/primary seal as it's otherwise known ) is 0.2 hours, only problem is you need to add the 3.9 hours to remove and replace the clutch, so bank on 4 hours labour.
#8 Gremlin
Gremlin
  • 2,142 posts
Posted 01 September 2014 - 08:22 PM
I doubt they will change the primary gear bush, it's not a 2 minute job, it has to be matched to your crank, unless you spend a lot of time on the clutch it will be fine, it only moves in relation to the crank when the clutch is pressed
#9 Gremlin
Gremlin
  • 2,142 posts
Posted 01 September 2014 - 08:23 PM
Beat me to it :)
#10 Stiggytoo
Stiggytoo
    Best Plucker?
  • 1,170 posts
  • Local Club: CCMOC
Posted 01 September 2014 - 08:39 PM
On an MPI there will be higher labour costs as the brake servo etc has to be unbolted and moved out of the way. I'm sure you know this though. :P 4 hours sounds about right.
Edited by Stiggytoo, 01 September 2014 - 08:46 PM.
#11 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 01 September 2014 - 08:41 PM
The above is the time for an MPi
