Some More Center Speedo Questions
6 replies to this topic
#1 Dusky
Dusky
  • 5,322 posts
Posted 02 September 2014 - 09:48 PM
Hi all :)
I have osme questions regarding my 'new' ( aka second hand) smiths center speedo :
First of all : what bulb do I need for the ignition warning light? Can I just use a standard bulb?
Second : Is it possible to 'reset' the speedo? its at 11000 KM atm, but I need to get it up to 58K or 0, but doign that mile per mile isn't going to work out ( would need roughly 11 hours of spinning it constantly).
Can I use bulbs from my 2 clock setup? Or are those a whole different type?
I think that's about it..
Cheers!
#2 Stiggytoo
Stiggytoo
    Best Plucker?
  • 1,170 posts
  • Local Club: CCMOC
Posted 02 September 2014 - 10:19 PM
Different bulbs. I believe you can take the speedo apart and alter the mileage
#3 Dusky
Dusky
  • 5,322 posts
Posted 02 September 2014 - 10:23 PM
It is apart now, but it seems like all th enumbers are stuck, so you have to turn :P
#4 Dusky
Dusky
  • 5,322 posts
Posted 03 September 2014 - 09:17 AM
bumpy
#5 TheJack
TheJack
    Formally known as Jackocola
  • 531 posts
Posted 03 September 2014 - 10:10 AM
bumpy
Following this post, want to put a centre in mine so this could become handy  :D
#6 dklawson
dklawson
  • 10,923 posts
  • Name: Doug
Posted 03 September 2014 - 11:34 AM
Google for the 27 page PDF document by Anthony Rhodes, "Repairing Jaeger and Smiths Speedometers".  Print out a copy, read it several times, then open your speedometer and work on its odometer.
#7 sansamn
sansamn
  • Just Joined
  • 47 posts
Posted 03 September 2014 - 02:55 PM
I recently reset the millage on a speedo I was going to fit to my Pick-Up. It is possible to ease the number reals over to the left and moved them on. It’s not quite as easy as that and I managed to break a couple in the process (or they were probably old and ceased to start off with). The end result was that I now have a speedo with the exact millage of my car BUT I can remember the TPM (Turns per Mile) of the speedo I used. In fact I don’t think any of the speeds I had in my spares match what I need so it all pretty much ended up as a pointless exercise really
