Timing Chain Failure
6 replies to this topic
#1 minihuss
minihuss
    Just On Tickover
  • 6 posts
Posted 04 September 2014 - 05:13 PM
New member needs some help!!!
My 2011 One d on 68K miles suddenly broke down. Got it recovered to my garage and he told me the timing chain has slipped causing the 3 of the rockers to smash. The internal damage is yet to be looked into
Took it to Mini and they have said for them to request a goodwill claim they need to strip it down and the cost of that is £2k.
Then even after that they are not sure if Mini will contribute.
The car ran out of warranty in Feb 2014, has got FMSH and I took out a new TLC in Feb.
I cannot understand how the chain would fail. I have read numerous reports of the tensioner failing so I am assuming this is what has happened here.
I am so disappointed with this, it was running perfectly before.
Any thoughts on what I can do with Mini?
#2 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 04 September 2014 - 05:36 PM
Take it to a specialist if Mini wont help, it depends if the pistons and bores and the cylinder head is damaged on the final cost but your not alone or the first to suffer this fault
#3 Badboytunes
Badboytunes
  • 1,615 posts
  • Local Club: MINIS Unleashed
Posted 04 September 2014 - 08:20 PM
These engines are quite robust ( they are Pug motors until the BMW units were used ) and im surprised you have issues at such a low mileage
Try http://www.minimatt.co.uk/ , http://www.p-torque.co.uk/
#4 sledgehammer
sledgehammer
  • 3,109 posts
Posted 04 September 2014 - 09:34 PM
£2000 to diagnose a fault seems a bit steep
I would be looking for a replacement engine & chain / tensioner replacement on it
if it's smashed 3 rocker's - then valves will be useless , Likely head damage / piston damage , etc
I would cut your losses & swap the engine
sorry to be cynical , but to spend £2000 - & still not know if MINI will pay for some of the damage would worry me somewhat
I wish you luck with this
Edited by sledgehammer, 04 September 2014 - 09:34 PM.
#5 minihuss
minihuss
    Just On Tickover
  • 6 posts
Posted 04 September 2014 - 10:15 PM
I was thinking the same thing.
Can get a reconditioned engine for £2k all in.
Thanks for the help
#6 The Matt
The Matt
  • 17,232 posts
  • Name: Matt
Posted 05 September 2014 - 07:26 AM
Moved to general chat
#7 minimanclive
minimanclive
  • 1,108 posts
  • Local Club: LSMOC
Posted 06 September 2014 - 07:40 PM
Is it definitely a chain and not a belt?  The R50 Mini One D with the 1.4 engine was a chain cam Toyota engine, but the later ones I thought had the 1.6 Peugeot based diesel engine which had a cam belt.
