Old Skool Minis
6 replies to this topic
#1 racingbob
racingbob
  • 3,061 posts
Posted 06 September 2014 - 09:20 AM
anyone else had lousey service from old skool minis
I wont be using them again first and last time
completely let me down
#2 robminibcy
robminibcy
  • 1,516 posts
Posted 06 September 2014 - 09:27 AM
I've used them a couple if times and had no problems
#3 gizmo1994
gizmo1994
  • 33 posts
Posted 06 September 2014 - 09:34 AM
I use them regularly. Never had any problems and service has always been good.
I assume you have already communicated with the proprietors regarding your issues and they have been given the opportunity to remedy the situation before you decided to post this thread?
#4 Badboytunes
Badboytunes
  • 1,615 posts
  • Local Club: MINIS Unleashed
Posted 06 September 2014 - 09:48 AM
Well said.
What is the issue?
#5 racingbob
racingbob
  • 3,061 posts
Posted 06 September 2014 - 10:12 AM
Well said.
What is the issue?
its the first time I have used them
and I rang them about a top hose as fitting a revote fan
told them it had to be the 1 inch inside diameter one the said ok
sent the wrong one
phoned them said what happened they must have sent wrong one
the one I have here is a 1 inch he said I said well send it me if you
post today will get it Monday he said ok and I said will send old one back
never arrived all week so phoned them they said oh need old one back first before we send replace
I said no that's not what you said. I said forget about it in a pissed off manner
wont use again
#6 69k1100
69k1100
  • 376 posts
Posted 06 September 2014 - 10:20 AM
What is the internal diameter of the one you were delivered? Maybe someone here would be interested in it?
#7 racingbob
racingbob
  • 3,061 posts
Posted 06 September 2014 - 10:34 AM
its 7/8 inside diam, will just keep as spare
was only about £6
revotec said get the 1 inch so can use the cutting tool
provided from the inside and get the insert in to push out thro
the hole, even then with 1 inch its tight
