hi all my car was playing up and misfiring a few weeks back and i checked all the plugs and they are all black with light brown color tips what says normal in the haynes manual anyway it was still spluttering. i changed the plugs and then retried it and it was a lot better and drove fine since. anyway today i started it up this morning all ok moved it of the drive as i was washing my other car i then come back to it later today and it was misfiring very bad wouldnt even go up the drive slope? i have now checked the plugs and 3 are black and one is wet. so i have put some second hand ht leads that i have got and its running ok but splutters when driving it. i have a electronic ignition new spark plugs everything else looks in good nick. what else could be making it splutter and keep missfiring.. thanks tom
What Else Can Cause Misfiring?
Posted 07 September 2014 - 06:42 PM
Posted 07 September 2014 - 07:03 PM
A bad dizzy cap, rotor arm, leads or even a loose connection(ive got this fault on our 998)
Edited by cal844, 07 September 2014 - 07:04 PM.
Posted 07 September 2014 - 07:18 PM
Posted 07 September 2014 - 07:25 PM
check that you're getting a spark from each of the leads and check your valve clearances
Posted 07 September 2014 - 08:19 PM
If the ignition and fuel checks out and the tappets are sect correctly, I'd be doing a compression test....
Posted 08 September 2014 - 05:40 PM
drove fine today abit of splutters when driving of this morning but i am sure thats just because engine is cold.. once warmed up it was fine. problem is with my travelling is i only have to travel down the road 10 min drive and then its turned of and left all day untill 5 and then i drive back 10 mins its not getting a good run in is it?
Posted 08 September 2014 - 05:49 PM
Posted 08 September 2014 - 06:03 PM
Posted 08 September 2014 - 07:28 PM
Check coil connections are good and dry also connector at dizzy is good and dry
I would put new cap and leads on as well.
Posted 10 September 2014 - 11:31 AM
Might sound stupid, but just check the plug gaps are set correctly - mine misfired for a good while and plugs were black - it ran much better when I re-gapped the plugs, mine were set too close together, my mixture was also a tad rich.
