Cutting Out When Apply Throttle
9 replies to this topic
#1 hellom8
hellom8
  • 188 posts
Posted 08 September 2014 - 06:48 PM
I have just installed a replacement engine.
With no trottle and no choke it starts and idles perfectly, but as soon as I touch the throttle the engine drowns out and a puff of petrol pops out of the carb.
If I pull the choke out, same result, engine dies.
Checked the spark plugs and they are sotty.
Any ideas as to what this might be?
Iggy
#2 Stiggytoo
Stiggytoo
    Best Plucker?
  • 1,170 posts
  • Local Club: CCMOC
Posted 08 September 2014 - 06:58 PM
This could be down to fuelling etc. Does the carb dashpot have oil in it?
#3 hellom8
hellom8
  • 188 posts
Posted 08 September 2014 - 07:07 PM
I pulled the dash pot plunger out, and it had plenty of oil on it.
I'll try topping it up.
I was thinking it maybe the mixture is to rich?
#4 Stiggytoo
Stiggytoo
    Best Plucker?
  • 1,170 posts
  • Local Club: CCMOC
Posted 08 September 2014 - 07:15 PM
Have you set the timing as well?
#5 minimender
minimender
  • 1,589 posts
  • Local Club: M.M.M.
Posted 08 September 2014 - 07:23 PM
Is distributor in good condition, new points, condensor, cap and leads?
#6 hellom8
hellom8
  • 188 posts
Posted 08 September 2014 - 07:25 PM
I haven't adjusted the timing.
I transfered the dizzy from one engine to the other, with both engines at TDC hoping the timing would be ok.
Can I check the timing with the engine running at idle?
#7 hellom8
hellom8
  • 188 posts
Posted 08 September 2014 - 07:27 PM
Its an electric dizzy and cap/rotor arm and leads are all good.
#8 Stiggytoo
Stiggytoo
    Best Plucker?
  • 1,170 posts
  • Local Club: CCMOC
Posted 08 September 2014 - 08:13 PM
You definitely cannot just transfer the dizzy like that and expect the timing to be spot on. You need a timing light to set it properly (by turning the distributor in the block)
Edited by Stiggytoo, 08 September 2014 - 08:13 PM.
#9 hellom8
hellom8
  • 188 posts
Posted 08 September 2014 - 08:34 PM
I'll get the timing gun out and have a check, cheers.
#10 hellom8
hellom8
  • 188 posts
Posted 09 September 2014 - 03:34 PM
Timing was at about 25 after TDC.
Moved the dizzy clockwise until it reached approx 12 before TDC and it started revving as should.
Thanks for the help.
