Hi there for a while now I've had a bit of a squeak and it's taken me a while to track it down and I'm pretty sure now it's the exhaust. I have a maniflow full system with a cooper free flow manifold and on the end of the manifold there is a bracket for attaching to the back if the gearbox and every time I re attach it to the bracket the squeak gets worse. My question is how can I get rid of this noise? I think the actual squeak is come from the small joining pipe between the manifold and the rest of the system.
Any help would be much appreciated
Squeaky Exhaust
Daniel_moody25
, Sep 08 2014 08:36 PM
2 replies to this topic
Posted 08 September 2014 - 08:36 PM
Posted 10 September 2014 - 11:59 AM
Bump
Posted 10 September 2014 - 02:49 PM
Is it loose ? its should be clamped up to the bracket off the diff and the pipes securely clamped, if you have a squeak are the stabliser bushes worn? also check the actual bracket off the diff, I've seen those fracture and the 2 edges produce a squeaking noise
Edited by KernowCooper, 10 September 2014 - 02:50 PM.
