Replacing Rear Knuckle Joints
7 replies to this topic
#1 coopdog
coopdog
  • 4,506 posts
Posted 09 September 2014 - 08:40 PM
My car is making a knocking noise from the back and I can't seem to put my finger on where from?
I'm gonna try and change the knuckle joints and see if that fixes it.
Do I need a cone compressor for changing the rears?
#2 Jordie
Jordie
  • 13,567 posts
  • Name: Jordan
Posted 09 September 2014 - 08:43 PM
Nope.
Simply undo the shock absorbers from the top inside the boot. This will allow the radius arm to drop lower and take the pressure off the cone/trumpet allowing removal.
#3 coopdog
coopdog
  • 4,506 posts
Posted 09 September 2014 - 08:48 PM
Nope.
Awesome!!
Anything else I should be looking out for?
#4 Jordie
Jordie
  • 13,567 posts
  • Name: Jordan
Posted 09 September 2014 - 08:49 PM
plastic cup usually ends up stuck in the arm and can take some removing.
Like wise, the knuckle can end up stuck in the end of the trumpet.
Jordie
#5 coopdog
coopdog
  • 4,506 posts
Posted 09 September 2014 - 08:53 PM
Jordie
Ok :D
Thanks mate
#6 HarrysMini
HarrysMini
    I do not have short legs!!!
  • 3,352 posts
Posted 09 September 2014 - 09:06 PM
Yeah the plastic cup can get stuck in the arm, mine have on the front and rear.
Spray some penetrating fluid in the gap, this usually helps.
#7 exuptoy
exuptoy
  • 674 posts
Posted 09 September 2014 - 09:10 PM
I destroyed both my rear ones when trying to replace them. Ended up with a screwdriver hammered into them and picked them out in bits!
#8 Tamworthbay
Tamworthbay
  • 7,025 posts
  • Name: Clive
  • Local Club: A5 minis
Easiest way to get the cups out is using a pair of needle nose pliers. Stick one half down the outside and then just keep twisting. It will wind the cup in and you can then put it out. It may split but just keep at it and it will come out.
