Tips And Guide To Replacing Water Pump
3 replies to this topic
#1 tom.cilano
tom.cilano
  • 85 posts
Posted 09 September 2014 - 09:17 PM
Has anyone got a tip and guide for replacing water pump on a 1275gt?
#2 cal844
cal844
  • 9,662 posts
  • Local Club: TFMOC
Posted 09 September 2014 - 09:24 PM
Remove radiator(possibly thermostat housing)
Remove alternator
Remove fan(ensure this goes on the correct way)
Remove fan belt (change along with the thermostat and water pump)
Flush system
Rebuild :)
#3 alex-95
alex-95
    I am THE CLAMP MAKER
  • 6,044 posts
Posted 09 September 2014 - 09:27 PM
Drain coolant, remove rad, fan, flush the sstem. unbolt waterpump you may need to tighten the bolts for this then loosen, tighten, loosen etc to get them out. clean off the old gasket.
#4 Gremlin
Gremlin
  • 2,142 posts
Posted 09 September 2014 - 09:35 PM
Nothing unexpected, drain coolant, take radiator out, fan and pulley off then water pump off. Worth replacing the bypass hose and the bottom hose depending condition and age as it's easy to get to with the radiator out and the fan off
