Strange Engine Noise
Posted 16 September 2014 - 04:08 PM
Posted 16 September 2014 - 04:22 PM
Posted 16 September 2014 - 04:27 PM
sounds like a stone caught in the 'stone guards' on the disk brakes.
air leak, mine does a squeaky sound at about 3000 rpm and i put this down to something to do with the air filter as it only happens at 3k exactly
Posted 16 September 2014 - 04:28 PM
High pitched noise? Squeal? Whine? Hum?
It's like a squeal
Posted 16 September 2014 - 04:34 PM
Posted 16 September 2014 - 04:38 PM
Posted 16 September 2014 - 04:56 PM
Posted 16 September 2014 - 05:04 PM
Or....
When stationary rev the engine, if it makes a noise then it could be the alternator... if it does not then it's not the alternator...
Absolutely no need to take the fan belt off...
If you want to diagnose the issue properly, ask yourself some basic questions...
Is the noise only present when I'm moving or is it there when I'm stationary, or vice versa.
Is the noise relative to engine speed, ie gets louder/quieter or changes pitch as the rpm increases until I change gear
Is the noise relative to road speed ie gets louder/quieter or changes pitch as the speed increases
Does it go away if I dip the clutch or select neutral while moving forward..
Does it make the same noise going backwards as well as forwards...
All simple things which can be done in a matter of minutes without having to even open the bonnet or get out of the drivers seat...
Edited by Guess-Works.com, 16 September 2014 - 05:10 PM.
Posted 16 September 2014 - 05:53 PM
Posted 16 September 2014 - 06:15 PM
So basically, it's something to do with the drive train...
As you've said previously, it's coming from the passenger footwell, I suggest it is something related to the n/s from wheel...
If you have a jack handy, jack up the n/s front wheel and give it a spin.
Posted 16 September 2014 - 06:26 PM
I have jacked it up and spun the wheel and there is a slight squeal but not as loud as it is when driven
Posted 16 September 2014 - 06:27 PM
try it again but put you hand on the stone guard ( the shield around the disk ), easier if you take wheel off...
Edited by Guess-Works.com, 16 September 2014 - 06:27 PM.
Posted 16 September 2014 - 06:48 PM
Ok will try that in the morning. What should I be looking out for?
Posted 16 September 2014 - 07:04 PM
You touch/hit/dampen things until the sound changes, then you can be pretty sure what you're touching, hitting or dampening is directly related to the noise which you're hearing....
