Group Buy: Nodiz Pro
14 replies to this topic
#1 adampat84
adampat84
  • 288 posts
  • Local Club: Dorset Mini Club
Posted 17 September 2014 - 06:15 AM
Hey all,
Contacted Matt @ Motorsport Electronics today about getting NoDiz Pro for my mini; after going through many coils and most recently being drowned in the rain at MITP changing one. I have decided to plump for Nodiz.
When I said I saw it on TMF in the group buy done back in February 2013 he was happy to do another. Normal price is £269 + VAT
If I can get 5 others we can have it for £235 incVAT + £8 for postage.
You will receive:
  • NODIZ Pro
  • unterminated loom
  • bluetooth dongle
Payment will be to motorsport electronics by Paypal
Last Group Buy: Link
NoDiz Site: Link
MotorSport Electronics Site: Link
Put some info from their site below (With Permission from Matt). Personally I like the gadgets so the android dash and launch control sound awesome!
If you interested put you name below and we will go from there..
NODIZ Pro™ Features
The NODIZ Pro™ is a state of the art microprocessor controlled digital stand-alone, fully mappable ignition controller for 4, 6 or 8 cylinder spark ignition engines. It can be used either to replace older distributor based ignition systems for more modern coil packs, or even to allow the running of carburettors on more modern engines which do not feature a distributor drive.
It is truly 3D, giving an advance angle based not only on engine speed but also on engine load, which can be derived from either its optional in-built Manifold Absolute Pressure Sensor (MAP), or using a potentiometer type Throttle Position Sensor (TPS).
Using MAP, means it can even be used to retard timing as boost increases, such as with turbocharged or supercharger configurations.
The NODIZ Pro™ is incredibly simple to install, and will always arrive pre-loaded with a suitable base-map of your choice. With only seven connections to make, you can be up and running in a matter of minutes, and if you opted for a pre-loomed system, this can be even quicker!
To use the NODIZ Pro™ you will need, at a minimum, the following components. All can be obtained from the other parts section of our website.
  • Trigger Wheel
    In the case of modern engines this will probably already either be cast into the flywheel, or fitted to the front pulley. Note that direct support for many OEM trigger wheels is being added. (Currently 36-1 and 60-2 is fully supported.)
  • Crank Sensor
    A standard 2 Wire VR type crank sensor for reading the Trigger Wheel.
  • Coil Pack
    Standard Wasted Spark 'dumb' coil pack. Ford style ones work best and universal ones are available from us.
If you are using a TPS based NODIZ Pro™, then you will also need a 3-wire TPS sensor fitted to your throttle linkage/carburettor(s).NODIZ%20Tuning%20Software.jpg
In addition to the above most direct and simple installation, the NODIZ Pro™ also features the following:
  • 16 Load by 16 Speed Sites, with full 3D interpolation and user definable Speeds/Loads.
  • User settable RPM Soft and Hard Cut Rev Limiters.
  • In-built coil drivers, no need for EDIS or other modules.
  • Coolant based ignition adjustment map (To add advance to cold engines, etc.).
  • Intake Air Temperature ignition adjustment map, to allow timing retarding based on intake temperature to reduce pinking on very high intake temperatures.
  • Cranking based advance angle to help start high compression engines.
  • A programmable Shift Light output.
  • 12v Tachometer Output.
  • Launch Control :: Customer Video
  • A programmable output based on either RPM (i.e. V-TEC control), coolant temperature (i.e. Fan Control) or Intake temperature (i.e. Water Injection control).
  • Bluetooth™ Communication (dongle provided) and apps currently being developed to allow tuning with your mobile, as well as GPS and video data-logging. Customer Video of NODIZ Dash in use.
Digital Dash for Android
Also, use your android phone or tablet for a fully featured digital dashboard. Android tuning software is currently in development and due for release soon....
Any Questions Just Ask?
Edited by adampat84, 18 September 2014 - 11:38 AM.
#2 adampat84
adampat84
  • 288 posts
Posted 18 September 2014 - 06:58 AM
Anyone?
1. adampat84
2.
3.
4.
5.
6.
#3 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 18 September 2014 - 07:49 AM
Can it be made clear what you are actually getting for your money...
Reason I ask is that it seems just to be a module
Do you also get
- Trigger wheel and sensor
- Coil Pack
- Bracketry
- Wiring Loom
- HT Leads
- MAP
- Lambda ( wide or narrow band )
- TPS
Anything else I may have forgotten....
#4 motorsportelectronics
  • 54 posts
Posted 18 September 2014 - 08:56 AM
Hi GW
It is the NODIZ ECU, unterminated wiring loom, and Bluetooth dongle.
Try not to think of it as a simple 'module' - it is a full ignition engine management system with all the features you would expect. A similar system with Omex, or DTA on the label (and these have less features) costs normally £150+ more!
We can supply all other parts if required but most source their own during the build ups. MED for example make an excellent trigger wheel iirc, and many NODIZ Mini users have used that in the past. That and a brand new Ford Coil pack is around £25-£35, and leads around £15, means its just more affordable to source locally than for us to ship the easily obtainable stuff...
You also wouldn't use lambda control with ignition only - as it has no control over the fuelling.
Hope that helps,
Regards,
Matt
Edited by motorsportelectronics, 18 September 2014 - 09:17 AM.
#5 motorsportelectronics
  • 54 posts
Posted 18 September 2014 - 09:27 AM
SMM,
I think the guy was just correcting the other one - doesen't really effect the NODIZ, its price, or the offer :)
I will have an admin clean it up as it is essentially irrelivant.
Regards,
Matt
#6 giacomo
giacomo
  • 684 posts
Posted 18 September 2014 - 09:28 AM
SMM,
Regards,
Matt
good call! i'll have a read up on there website, could be a good buy for when i drop the new engine in ;)
#7 adampat84
adampat84
  • 288 posts
Posted 18 September 2014 - 11:40 AM
Do you also get
- Coil Pack
- Bracketry
- Wiring Loom
- HT Leads
- MAP
- TPS
I wrote the first post twice fro some reason i left this out.. Fixed.
#8 Mini ManannĂ¡n
Mini ManannĂ¡n
  • 2,860 posts
  • Local Club: man Estate
Posted 18 September 2014 - 12:48 PM
Do you also get
- Coil Pack
- Bracketry
- Wiring Loom
- HT Leads
- MAP
- TPS
I'm confused now.  I wouldn't be able to get any of these components on this rock, can you tell me the price for the complete kit as above?
#9 WiredbyWilson
WiredbyWilson
    WiredByWilson
  • 5,004 posts
  • Local Club: WiredByWilson
Posted 18 September 2014 - 12:59 PM
To get all the extra bits youre probably looking at £150 - making the kit around £380 which is not far off MJ kits out there with custom terminated looms.
I'm still waiting to see results form this system as it seems the answer to not finding an EDIS unit, which is the MJ central component.
And it is possible to lose a spark on one cylinder, I don't pretend to understand how due to how they are set up. I changed a coil pack on my mrs bosses ford focus two weeks ago, misfire on pot 4 as per diag, new coilpack and job done.
#10 adampat84
adampat84
  • 288 posts
Do you also get
- Coil Pack
- Bracketry
- Wiring Loom
- HT Leads
- MAP
- TPS
I believe you will only require the following:
- Coil Pack
- Bracketry
- Ignition Leads
I have emailed Motorsport electronic for clarification.
#11 coopdog
coopdog
  • 4,506 posts
Posted 18 September 2014 - 03:52 PM
Do you also get
- Coil Pack
- Bracketry
- Wiring Loom
- HT Leads
- MAP
- TPS
- Coil Pack
- Bracketry
- Ignition Leads
Tps or map sensor!!
Edited by coopdog, 18 September 2014 - 03:53 PM.
#12 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,089 posts
  • Name: Neil
Posted 18 September 2014 - 06:09 PM
Gentlemen this has gone so far off track it needs to be cleaned up. Please do not be offended if i have removed your posts.
Right we are now back on track so please keep it this way.
#13 adampat84
adampat84
  • 288 posts
Posted 22 September 2014 - 11:24 AM
Anyone??
#14 boy
boy
    Starting My Mini Up
  • 2 posts
Posted 27 November 2017 - 05:35 PM
Bit old I know. Can this be raised from the dead? Any further interest?
#15 boy
boy
    Starting My Mini Up
  • 2 posts
Still game if it can be revived?
