Brake Fluid
8 replies to this topic
#1 matt050990
matt050990
    I have upside down nipples
  • 1,199 posts
  • Local Club: Currently Ridin' Solo :)
Posted 17 September 2014 - 01:56 PM
Hi,
Bit of a stupid question, :withstupid:
What type of brake fluid do I need for my 1978 850?
I normally just check Dot 4 in there but after reading the spec it says it for discs up front and drums on rear or discs all round.
I have never had any problems in the past but thought I would check before buying more....
#2 HarrysMini
HarrysMini
    I do not have short legs!!!
  • 3,352 posts
Posted 17 September 2014 - 02:18 PM
It should be DOT 4. When was it last changed? If more than 2 years ago, it needs replacing.
#3 matt050990
matt050990
  • 1,199 posts
Posted 17 September 2014 - 03:27 PM
I flushed the system about 6 months ago but had a leak so it needs refilling
ill get some more dot 4 then.
#4 gazza82
gazza82
  • 3,019 posts
  • Local Club: TMF+
Posted 17 September 2014 - 03:42 PM
You don't get any new cars with drum brakes at the front now, so they don't bother putting it on the bottle/can.
Don't buy a lot as once opened it has a short shelf life ... it absorbs water so once the seal is broken that process starts. Same in the car so it recommended you flush it completely with new fluid about every two years.
#5 Anthony30
Anthony30
  • 1,467 posts
  • Local Club: N/A
Posted 17 September 2014 - 03:53 PM
I use AP Racing DOT 5.1 mineral. Bit OTT really. :proud:
#6 Tamworthbay
Tamworthbay
  • 7,025 posts
  • Name: Clive
  • Local Club: A5 minis
Posted 17 September 2014 - 03:58 PM
is that one compatible with Dot4? I know some of the 5.1s are but some others aren't recommended unless as a clean install.
#7 Anthony30
Anthony30
  • 1,467 posts
  • Local Club: N/A
Posted 17 September 2014 - 04:22 PM
Just had a look in the garage, and it does not appear to be mineral based. Just found this on www.apracing.com. So I'm not sure really. I would always advise other people to use normal DOT 4, if asked. >_<
'AP Racing Formula DOT 5.1 fluid will mix safely with other DOT 5.1 fluids along with DOT 3 and DOT 4 Fluids conforming to the above specifications.
Note: Not suitable for vehicles with Mineral Oil Systems.'
AP Racing Formula DOT 5.1 is a premium specification Motor Vehicle Brake and Clutch Fluid which conforms to and exceeds the current international specifications U.S. FMVSS No 116, DOT 3, DOT 4, and DOT 5.1, S.A.E. J1703, SAE J1704 and ISO4925. Suitable for High Performance Road Applications including vehicles fitted with ABS and ESP.
AP Racing Formula DOT 5.1 is non silicone based.
Superior -40°C (-40°F) viscosity makes it suitable for vehicles operating in cold climates.
O_O  :unsure:
#8 HarrysMini
HarrysMini
  • 3,352 posts
Posted 17 September 2014 - 04:30 PM
It is worth noting that you must never mix DOT4 and DOT5. The latter is a silicone based fluid, unlike DOT5.1.
#9 matt050990
matt050990
  • 1,199 posts
Posted 18 September 2014 - 05:00 AM
I'll just get a bottle of the dot 4. The system is completely empty now so will get a 1lt bottle to make sure I have plenty.
