Spark Plugs
14 replies to this topic
#1 Austin mini 30
Austin mini 30
  • 332 posts
Posted 17 September 2014 - 07:35 PM
I have a 1989 mini 30, and the engine is out of the car for some maintenence just now. Whilst it's out I was going to replace the spark plugs.
Just wondering the code of spark plug I should use and the what the gaps should be set to. The old spark plugs have the code BP6E (brand NGK), not sure if this is correct though.
It is a 998cc engine.
cheers
Edited by Austin mini 30, 17 September 2014 - 07:39 PM.
#2 cal844
cal844
  • 9,646 posts
  • Local Club: TFMOC
Posted 17 September 2014 - 07:40 PM
I use BPR6ES but you can use BP6ES
#3 silve1999
silve1999
  • 1,146 posts
  • Local Club: MiniFreakz, Brighton Mini Club
Posted 17 September 2014 - 07:42 PM
I use the same as cal
#4 Austin mini 30
Austin mini 30
  • 332 posts
thats great, cheers. is it ok that the car has been running on these BP6E plugs? didnt seem to bother it.
whats the gaps?
#5 cal844
cal844
  • 9,646 posts
  • Local Club: TFMOC
Posted 17 September 2014 - 07:50 PM
To be honest i dont know i never check the gaps, i just make sure the gaps look the same and fire them in.. If the car runs ok, i advise using the same plugs
Hope this helps
#6 Austin mini 30
Austin mini 30
  • 332 posts
Posted 17 September 2014 - 07:53 PM
cheers, looked in the manual and the gaps are there thanks
#7 cal844
cal844
  • 9,646 posts
  • Local Club: TFMOC
Posted 17 September 2014 - 08:02 PM
No problem, id suggest you change the rotor arm, cap , leads
(so they are new and clean)
#8 Austin mini 30
Austin mini 30
  • 332 posts
Posted 17 September 2014 - 09:42 PM
Just been done, only have done 30 miles on them, just the spark plugs needing done
#9 cal844
cal844
  • 9,646 posts
  • Local Club: TFMOC
Posted 18 September 2014 - 09:58 AM
Thats perfect!
#10 IainNeon91
IainNeon91
  • 1,287 posts
Posted 18 September 2014 - 10:26 AM
I use BPR7ES, this is a 'colder' plug to prevent hot spots with my high compression engine.
#11 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 18 September 2014 - 01:47 PM
If you have electronic ignition then you should use the "R" plugs, eg BPRn* and when using points BPn*
For standard engines the '6' plugs should be fine, but you may want to use the '5' plugs on lower compression engines and 850's, 7's and 8's should only be used if you start getting electrodes burning out on higher performance engine. Using a plug which is too cold can be even worse than using one which is too hot.
#12 Dusky
Dusky
  • 5,322 posts
Posted 18 September 2014 - 04:20 PM
Whats the difference between these 2 ( BPRn and BPn)?
Edited by Dusky, 18 September 2014 - 04:20 PM.
#13 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 18 September 2014 - 04:26 PM
R is restive plugs the other is not
#14 Dusky
Dusky
  • 5,322 posts
Posted 18 September 2014 - 06:16 PM
^But what is the advantage of that? :P Would it cause any abnormalities when using non restive plugs?
#15 Cerberus
Cerberus
  • 989 posts
Posted 18 September 2014 - 06:37 PM
Straight from the source
http://www.ngksparkp...faqresistor.asp
And
http://ngkntk.co.uk/...resistor-plugs/
