Mg Metro Engine - Just Installed - Wont Fire
8 replies to this topic
#1 sshenton1975
sshenton1975
    Just On Tickover
  • 5 posts
Posted 18 September 2014 - 11:52 PM
Hello all
Just fotted a mg metro engine to my mini. Not heard it run but appears to be good health
All wired up and attempted to run. Actually got leads 2 and 3 round the wrong way amd it started albeit rough
Swapped over but now wont run at or fire at all. Spark plugs 2 and 3 appear to be firing but 1 and 4 are completely clean (4 new plugs)
Engine has accuspark fitted which i think i have wired correctly. Rotor appears to be pointing at 1 oclock at top dead centre
Fuel is getting through
Bit puzzled really
I did think about whipping put old ppints distributur from my 998 and trying that?
Any reason why plugs 1 and 4 would appear not to be firing?
Edited by sshenton1975, 18 September 2014 - 11:53 PM.
#2 Fast Ivan
Fast Ivan
  • 2,910 posts
Posted 19 September 2014 - 07:24 AM
checked your valve clearances?
#3 timmy850
timmy850
  • 3,394 posts
  • Local Club: MITG
Posted 19 September 2014 - 07:49 AM
Have you wired 1 & 4 correctly?
#4 Stiggytoo
Stiggytoo
    Best Plucker?
  • 1,170 posts
  • Local Club: CCMOC
Posted 19 September 2014 - 08:09 AM
Are 1+4 wet? You say they look clean but I don't know what you mean by this
#5 Stiggytoo
Stiggytoo
    Best Plucker?
  • 1,170 posts
  • Local Club: CCMOC
Posted 19 September 2014 - 08:10 AM
Edited by Stiggytoo, 24 September 2014 - 01:16 PM.
#6 sshenton1975
sshenton1975
    Just On Tickover
  • 5 posts
Posted 19 September 2014 - 09:17 AM
Havent checked gaps - will do this
I have a feeling plugs 1 and 4 are not firing at all
Plugs are new but distributor is unknown
LOokS brand new and has accuspark in it. I have non ballast ignition in the mini so i simply wired to the coil. Coil has 3ohms across it and 12 volts.
Timing - at top.dead centre on piston 1, valves are closed on cylinder 1 and valves rocking on cylinder 4. Rotor points to lead 1
Could it be dizzy is out by 180 degrees? How is that diagnosed?
Could i bolt in my 998 dizzy (i know this works) with points just to get engine running?
#7 Badboytunes
Badboytunes
  • 1,615 posts
  • Local Club: MINIS Unleashed
Posted 19 September 2014 - 11:12 AM
If the plugs are not firing then they should be wet and stink of fuel.......
Are ALL of the leads on the right way round?
#8 miniboy1993
miniboy1993
  • 274 posts
Posted 19 September 2014 - 08:51 PM
This might help :)
#9 LAYZeBOY14
LAYZeBOY14
  • 40 posts
  • Local Club: GMOC
Posted 29 September 2014 - 09:29 PM
Pretty sure firing order is 1-3-4-2 starting from radiator this is number 1 as of the photo nuber 3 and 4 need to be swapped round
double check i could be wrong :)
