Caliper Seals
8 replies to this topic
#1 skoughi
skoughi
  • 1,199 posts
  • Local Club: Shetland classic car club
Posted 19 September 2014 - 09:05 PM
I've been struggling to fit new caliper seals tonight and was looking for some advice. I've got 8.4" brakes and im fitting new stainless pistons, which l gave a good polish on the bench grinder (with a polishing mop!) And managed to fit one piston with seal. I was going to smear the seal and piston in some dot4 but the fitting instructions said to fit them dry, surely a bit of fluid won't hurt will it? I managed to squeeze in the piston ok in spite of everything being dry but the dust seal was a bit of a mare! I think im going to have to make a gadget thingy to get the dam thing to go in square, nearly wrecked the first attempt tonight! Any tips on what to use on getting this bugger in? I haven't split the calipers by the way.
#2 FlyingScot
FlyingScot
  • 2,664 posts
Posted 19 September 2014 - 09:32 PM
I use brake fluid to lubricate the piston and seal (to prevent tearing). Dust seal I put in with a steel plate (was a tool for pulling laminate floor together).
A g clamp on either side of the plate and wind down together evenly.
Attached File  image.jpg   59.87K   16 downloads
Attached File  image.jpg   54.7K   12 downloads
Attached File  image.jpg   52.17K   14 downloads
FS
#3 pogie
pogie
  • 498 posts
  • Local Club: Essex MC
Posted 19 September 2014 - 09:45 PM
I find it easiest to fit the dust seal once the piston was fitted.  Doing it before the piston nearly always leads to it getting damaged.
#4 skoughi
skoughi
  • 1,199 posts
Posted 19 September 2014 - 09:46 PM
Thanks for that, a smear of dot4 will greatly help I think. Are you screwing down the piston along with the dust seal then? I thought of doing this but feared the seal would come up over the chamfered edge of the piston, obviously it doesn't!
#5 skoughi
skoughi
  • 1,199 posts
Posted 19 September 2014 - 09:47 PM
Just noticed what you've used, I've got one of those under the bench!!
#6 FlyingScot
FlyingScot
  • 2,664 posts
Posted 19 September 2014 - 09:51 PM
Piston in then leave about 10 - 15 mm (1/2 inch in old money) sticking up out of the caliper. Lubricate the dust seal with red rubber grease or brake fluid and wiggle done the piston until touching the caliper casting.
Wind the plate down evenly which pushes the dust seal in and piston flush with caliper face ( almost as the piston stays slightly proud)
FS
Edited by FlyingScot, 19 September 2014 - 09:53 PM.
#7 FlyingScot
FlyingScot
  • 2,664 posts
Posted 19 September 2014 - 09:52 PM
That's how I found mine! The taper on mine matched the caliper.
FS
#8 skoughi
skoughi
  • 1,199 posts
Posted 19 September 2014 - 10:35 PM
Love it! Its great when you find stuff thats laying around the garage does a fantastic job doing something it was never designed for!
#9 skoughi
skoughi
  • 1,199 posts
Posted 20 September 2014 - 06:40 PM
Cheers for the tip Flying scot! I dug out the laminate flooring tool and a couple of g-clamps and the dust seals poped in nae bother! Both calipers now ready for bolting on, cheers!
Attached File  DSC_0095 (640x480).jpg   218.05K   14 downloads
